Results 1 to 43 of 43
Thread: Cambo Aptus DB: Any Landscape Photographer?
    May 2010
    San Francisco Bay Area, California
    367
    2
    Just interested to know whether any landscape photographer is using Cambo Actus DB or not.
    If so, what's your experience?
    I'm seriously considering this relatively new toy.
    [I apologies for incorrect heading... should be Actus, not Aptus]
    Sep 2010
    UK
    1,386
    Re: Cambo Aptus DB: Any Landscape Photographer?
    Me too seems like an excellent camera and have been drooling over one all week poised on the buy button - great price for such a specialised camera.
    What confuses me is lenses? So I understand if I use the Actus with a RS 32HRW and FF MFD back its equivalent to 21mm on FF 35mm. What happen if I also use the Actus with a A7r, is the lens only a 32mm or is there some conversion involved. Seems an expensive way to get a 32mm lens with movements.
    Brooklyn
    4,043
    1253
    using a 32mm lens on a 35mm camera is just a 32mm lens on a 35mm camera.
    using a 32mm lens on a mfdb will capture more field of view, as much as a 21mm lens would on your 35 camera.
    going backwards, if you want what a 21 will do on a 35 camera, but are using a mfdb, you would need a 32mm lens on that mfdb.
    confusing, eh?
    Vancouver, WA
    5,490
    543
    Well actually a 32mm lens is always a 32mm lens ... But yes the FoV will change for equivalences based on the film/sensor size.
    In Subrata & John's cases the 32hr with a 44x33 is equivalent to the FOV of 25mm lens on a 35mm sensor. However, it's still got the characteristics of a 32mm lens.
    Little Rock AR
    1,671
    Quote Originally Posted by gazwas View Post
    As Jim said, the 32mm on a 35mm is 32mm. No gain or loss. and you are right, a very expensive way to get movements unless you are lucky enough to already own a 32mm Rodie.
    I don't know of the Actus will allow the SK35 to be used in a normal lens 0 board or not. But it's wider than the 32mm and will not give you hardly any movement, about 7mm or less due to the color cast issues from the A7r and A7.
    The Rodie 28 would not get to infinity with the Acra DSLR2, again not sure what it would do on the Cambo solution. And if the 28mm won't work, I doubt a 23mm Rodie will either.
    Where this solution will really work well is with medium range, 60mm SK or 70mm Rodie and the telephotos. 90mm, to 180mm. The Sony Live View with focus peaking is hard to beat from my experience with the DSLR2. But on the wide side, you are looking at either a very expensive 32mm Rodie, which is not that wide, or the 40mm Rodie which is even less.
    Paul
    Sep 2010
    UK
    1,386
    This is what I suspected.
    I'd like one for studio work which it could easily do with longer lenses but I'd like it to double act as an architectural camera with an A7/A9/5Ds (and for fun landscapes) and was unsure about the wide lenses. I take it there is no control options for electronic lenses available?
    So its still a better platform for MFD than it is for 35mm when needing WA lenses...... shame.
    Brooklyn
    4,043
    1253
    i was able to focus the 28rodie (WRS mount) at infinity using the actus and my custom lens board.
    May 2010
    367
    2
    On wide side, Jim has already tested with 28 HR.
    However, per CI Blog by Steve Hendrix:
    "The good news is that in the same way we have seen with technical cameras like the Cambo Wide family, there are amazing optics available from Schneider Kreuznach and Rodenstock that are as wide as 23mm (which is – unshifted – equivalent to a 15mm lens on a full frame 35mm camera). So this turns the Cambo Actus DB into a true studio/landscape hybrid product. It’s a great studio view camera option for a digital back to mount to for product photography, but also, due to the ability for compressed distance between the rear optic and imaging plane, becomes a very capable landscape view camera for digital back owners."
    Not sure whether Steve tested with 23mm or not, though I should be able to manage with 40mm / 43mm on wide side. Max 28mm.
    In the picture, I didn't notice any scale for vertical rise & fall though. Also wondering how well bellow will survive in light rain, snow or will it vibrate in the windy condition.
    Bottom line is, can it be replacement of my Arca Swiss RM3di?
    Tucson/Carmel/Jackson Hole
    4,247
    Thinking off the top of my head, I'd have to say the bellows is the least of my concerns when shooting outdoors and base that on what used to be used (and in some cases still being used) in large format film days. If anything I'd suspect the material that's used now for the bellows is much better than what was being used 50-years ago.
    I really like the concept of this camera for landscape work and had put it behind me until John got the idea to manufacture his own Cambo lensboards. The reason I didn't like this before was that I'd have to invest in yet another set of lenses, at least now it looks like all I'd need is the body and Johns board.
    Looking forward to seeing this in Tahoe next month but afraid for my wallet!
    Don Libby
    Iron Creek Photography
    Blog
    Tucson AZ
    Aug 2008
    Carmel/Tucson
    2,218
    ....nothing that "Kenna and Donna" and a roll of duct tape can't solve.
    4,247
    Anyone know of a reliable bail bondsman in the Reno/Tahoe area?
    Don Libby
    Blog
    Tucson AZ
    May 2010
    367
    2
    If you need Actus DB as an additional toy, then yes, you need Johns board.
    However, if it is a complete replacement, then I guess you can un-mount from Cambo lensboard and mount on std. lensboard, which is $159 each only.
    If John is going to make boards for Arca "R" lens mount, then that will be nice too for my existing lenses, so I can keep the option open for future Arca use.
    I just don't want to add Actus DB in my bag as an additional item. Rather I'm trying to reduce the weight and size of my camera bag and over all cost.
    Brooklyn
    4,043
    1253
    bit by bit:
    as soon as i can get my hands on a lens with arca mount i'll figure out an Actus board for it.
    no, the actus does not have a vertical shift scale; i'm working on that, don't want to just put on a paper sticker though.
    the bellows is fairly thick leather and quite substantial. my only gripe is that it is larger than it needs to be, partially due to the construction method so it can close down to 3/8" (9mm): it will extend 6" (150mm). the camera only extends about 4-1/2" (115mm). a traditional accordion bellows would work but not compress as much. i found the alpa 72mm lens with extension in the front needs the bellows to compress all the way to get to inf focus and in fact had to make my lensboard thinner to get it to work. the cambo 28 was not so fussy.
    main advantages over any other tech camera: full movements with any mounted lens, cost is low, construction quality is high, lenses will be cheaper (no fussy shimming or helicoids)
    note: you will need live view on your back; there is no other way to focus
    recessed lensboards are a pia, as the lens controls, including the sync cable are considerably harder to reach.
    the imaging process is: fit lens and back (quick and easy), connect sync cord, open shutter and aperture, put back in live view, rough focus with slide, then fine focus using magnify (i use a shaded 6cm x 6 cm 3x power loupe as well) (rail precision is fine enough); movements, etc. close shutter, set aperture, take back out of live view, cock and fire. at least you don't have to remember to remove the dark slide (and reverse it, remember that?)
    at the tahoe gig we can try all sorts of standard mount alpa and cambo lenses
    Aug 2012
    933
    Another option would be to go old school and use ground glass..
    Peter
    My website
    May 2010
    367
    2
    Quote Originally Posted by Pemihan View Post
    I never used ground glass, as I'm relatively very new in tech cam camp. However, I'm under the impression that it is hard to use GG with wide angle lenses. That's what I was told.
    Subrata
    Aug 2008
    Carmel/Tucson
    2,218
    Subrata, you don't need to make up any more excuses to buy the IQ150/Credo 50 that you want for live view on the Cambo Actus DB.
    Buy it already.
    May 2010
    367
    2
    Buy it already.
    Ken, my excuse is not really for Credo 50. As of this morning, it is awaiting in custom clearance. :-)
    I'm just trying to justify Actus DB over RM3di.
    RM3di is a great camera with precision focusing, but I'm also first generation immigrant, so every penny counts!
    Subrata
    Jun 2008
    Tampa, Florida
    45
    Live View on the Credo/IQ150 works quite well on the Cambo Actus DB. Very precise and smooth. I was using it with the Schneider 120 ASPH yesterday. We found out the hard way that the standard rial would not focus a 120mm ASPH lens, so we had to get the AC330 Long Rail and AC DB-254 bellows. That worked well and gave us plenty of room on the rail to focus at infinity and close up.
    I have to say that is a very sweet setup.
    Quote Originally Posted by subrata1965 View Post
    Subrata
  19. #19
    May 2010
    367
    2
    Quote Originally Posted by Digitalcameraman View Post
    Chris, please send this setup to Tahoe next month, so we can test drive.
  20. #20
    Oct 2014
    81
    I'm checking to see if this is a possibility; I'll get back to you when I get word.
    Chris Valites
    Research, Marketing & Support, Capture Integration
    Email-Me
  21. #21
    May 2010
    367
    2
    Here we go with Clyde Butcher, Cambo Actus but with SONY A7r.
  22. #22
    Brooklyn
    4,043
    1253
    bump for graham
  23. #23
    Little Rock AR
    1,671
    I found the Live View focusing with the rm3dibwas not the piece of cake I thought it would be. Instead I found it very difficult to tell when an image was focused 100% correctly due to the extremely fine focus adjustment of the Arca. Using a rail system like the Aptus or Univeralis the image will pop more into focus as the focus increments are much greater.
    Paul
  24. #24
    Brooklyn
    4,043
    1253
    not sure why you could not get the 120 to focus with standard rail and bellows...at full extension of rail and bellows you should be able to close focus at about 10' or so. not macro, but in the standard range of a 120 with a helical focus. this with a DB, not the sony, which moves the sensor further away yet
  25. #25
    May 2014
    82
    does anyboday have experience in cambo actus with a ccd sensor - especially iq60 or 80.
    is a good liveview essential ?
    [ no picture ]
  26. #26
    Vancouver, WA
    5,490
    543
    TBH I only considered the Actus DB once I'd got CMOS live view. Whilst I'm sure that you can use ccd live view I personally found it very disappointing even on my Alpa with my IQ260/160. I think that you'd have more success using the cambo ground glass adapter and then swapping over to the ccd back.
    Unlike with a tech camera with helicoid there is no way to view the focus distance on the Actus db other than potentially setting the infinity limit stop and calibrating to that.
  27. #27
    Oct 2012
    Nyköping Sweden
    982
    One small reflection is that the Cambo can be used with Canon lenses, too. All of the 12-24/4L, 16-35/4L, 17/4L and 24/3.5LII give pretty generous image circles and they should be perfectly usable with 1.3X crop backs.
    All these lenses are retrofocus designs, so they play well with the CMOS based backs.
    https://www.youtube.com/watch?v=TDCC...=ChieJoongkeun
    The Canon 17/4 and the 24/3.5 TSE LII have been said to cover full frame 645.
    For personal experience I only have the 16-35/4L and the 24/3.5 TSE LII, but I have only used them on the A7rII. The 16-35/4 only allows something like 3 mm shift at 16 mm but 20mm up it is pretty generous.
    HCam Master TS 11-24mm
    Regarding 11-24/4L on Iq 250, P45+, Iq 380:
    HCam B1 with Canon EF-L 11-24mm New wideangle records
    That said, Rodies are probably better corrected, especially in the corners, but if you don't have important subjects at the corners those Canons may be an interesting option.
    Best regards
    Erik
    Paul
  28. #28
    Mar 2012
    Sweden
    1,531
    Subrata
    Yes it's hard, but it's possible. I do it with the symmetrical Digitar wides, which should be a magnitude harder than the retrofocus Digarons. Haven't tried any of those though.
    The Actus is not great with ground glass though as there's no sliding back. I would not like to use ground glass without a sliding back, however that was how you did it back in the film days, so I guess you could live with that too :-)
  29. #29
    Mar 2012
    Sweden
    1,531
    How rigid is the Actus? How good is the parallelism? That would be my main worries with that camera as it doesn't really look that rigid, even for a view camera.
    However, if you don't shoot with larger aperture than f/11 and don't shift the wides too much, the depth of focus will probably mask any parallelism issues.
  30. #30
    Mar 2012
    Sweden
    1,531
    Quote Originally Posted by gmfotografie View Post
    There is no sliding back in the system as the camera is too weak to hold one, so using a ground glass will be extra cumbersome (detach back, reattach ground glass). You'd probably not want a sliding back anyway as the big thing with the Actus is that it's small and light, and if you add a sliding back to it, you could just put an Arca-Swiss Universalis in the bag instead (which has a sliding back in the system), or even better a Linhof Techno (more compact and easier to pack, better ground glass, but unfortunately much more expensive).
    Those CCD backs you mention actually have a primitive live view which works in narrow lighting conditions. I know some actually use it. When it's too bright conditions you can use ND filters, but when it's a bit dark I guess you can't use it, and then it's either on/off with ground glass or trial-error focusing (shoot, 100% view, adjust shoot, 100% view, adjust etc).
    I don't think there is any specific about the Actus, you can ask anyone using a CCD with a view camera. Oh the specific with the Actus is that there is no sliding back, which is the most common option when CCD is used on a view camera.
    There is a ground glass though, so if you can accept detach/reattach ground glass when shooting you can do without live view.
    I don't know about the quality of the Cambo ground glass though which does matter quite a bit especially when working with wide angles. I know it has a fresnel, which is good, but the efficiency of the fresnel and the ground glass grain size varies a lot between brands. There's tradeoffs to make in design, larger grain usually makes the ground glass brighter, but harder to pinpoint focus with a strong loupe (that's why I don't like Maxwell Optics ground glass), and the fresnel is designed for a specific focal length, I prefer it to be designed for really short ones as brightness is not a problem with longer lenses anyway. I've tested a few ground glasses and Linhof's new bright ground glass is the best I've tried, but unfortunately I haven't tried Cambo's so I don't know how it compares.
    So you need to know 1) is the CCD live view on these backs effective enough for your use cases, 2) if you intend to use ground glass instead or as a complement, how good is the Cambo ground glass.
    Ground glass has very poor reputation, that's a key reason why so many went for the pancake cameras as you don't need to use it then. It's not impossible though, and I've used one since 2012. The key to success is a good ground glass, a strong loupe (more than 10x, I use 20x), decent eyesight, proper shading, good technique and training.
    Here's my review of Linhof's new bright ground glass which gives some insight into how it is to use a ground glass:
    bright ground glass review
  31. #31
    Jun 2008
    Tampa, Florida
    45
    I have several customers using the Cambo Actus DB with CCD backs, both IQ140 and IQ180. These guys are shooting products in the studio and when you have the set illuminated with modeling lamps, there is plenty of controlled light to use Live View to rough in the composition and focus. Is it as good as CMOS 50/100 MP? Not even close. But useable.
    I also found that when shooting indoors like at Silo City in rooms that are using mostly window light, it was adequate for rough composition and focus. Once the shot is captured, in a sec I can zoom into back or computer to check focus on captured image.
    The problem with the CCD backs and Live Focus is when you have very bright scenes, like outside in full sun, you need to put ND filters on the lens to allow the CCD to create an exposure that one can see.
    So it works and we have folks using it, but the CMOS 500/100 combination with Cambo Actus is much more productive and precise for landscape, studio, or art repo.
  32. #32
    May 2014
    82
    thanky you for your help. another question according the lens.
    the newer ccd or cmos backs with the actus in combination with old lenses like the apo sironar s 150mm or fujinon 125mm - does anybody now how these lenses will work on such high resolution backs?
    i have a lot of such old "good" lenses (planar, sonar, fujinon , schneider) and i' m trying to find a solition also using those lenses. knowing that the quality is not perfect.
    [ no picture ]
  33. #33
    Vancouver, WA
    5,490
    543
    I use the APO-Sironar digital 135mm with my Actus DB+ and IQ150. Not sure why but it's a little trickier to focus with live new vs my 32 & 70HR lenses (I find it easier to use if I open it up and then stop down to shoot) but results have been great. Acuity seems a little less than my SK150 that I had but to be honest I'm only comparing dozens of images taken with the 135mm vs hundreds taken over many years with the SK150 which was on my Alpa.
    Update: Rodenstock designed the APO-Sironar-digtal for use with sensors down to 9um pixels vs 4-5um sensors for the Digaron-S and HR/HRW/HRSW. That said, I have no real complaints with my 135mm images, especially in print. They are a bargain IMHO. If I were shooting with a IQ3100 maybe I'd notice it I suppose.
    There's a Rodenstock document out there that explains Sironar -> Digaron etc branding and which lenses were essentially reformulated and which were just rebranded. I'll see if I can find the link as I think I still have it (http://www.rodenstock-photo.com/Arch...grafie%20e.pdf).
  34. #34
    Senior Member DougDolde's Avatar
    Oct 2015
    Joshua Tree, CA
    292
    Clyde Butcher
    https://www.facebook.com/clydebutche...52235044632007
    Looks like a real monster with the RB lens on it
  35. #35
    Oct 2012
    Nyköping Sweden
    982
    Great!
    I am considering the Actus. Meanwhile, I am using the HCam Master TSII: Some examples of Tilt (or shift) with Sony A7rII and the HCam Master TSII
    So I may end up buying the Actus or something similar. The Actus has a lens plate that can set the aperture on Canon lenses, I would love that. The Actus has geared movements, I would love that, too.
    On the other hand, I have the HCam master in my bag and I can put it in my pocket… That is also an advantage!
    My take, if you do a lot of movements, the Actus may be a natural choice. If movements are needed now and then, the HCam Master II may be the ideal partner for the job.
    That said, the Actus may be on my shopping list, at this stage I simply don't know…
    Best regards
    Erik
    Quote Originally Posted by DougDolde View Post
  36. #36
    Vancouver, WA
    5,490
    543
    I have the Actus DB+ and I did also have an Actus with Sony mount. Both work the same and to answer Torger's question about rigidity - it is, albeit I'd prefer to be able to lock the front swing control.
    The big difference though is with use of wide angle lenses. The DB/DB+ and MFDB can use any wide tech lens as there is no mount restriction on how close the rear element can get to the full sensor. With the Actus and Sony, even if using the special wide adapter version, the rear element can protrude into the camera body, limiting movements etc.
    Be aware also that there are differences also in the lens support between them as the DB version relies on a sync trigger for the back and a shutter in the lens. The Actus with mirrorless or dslr just needs the aperture to be stopped down as there is a focal plane shutter in the body. Hence no sync required either. This allows for support of practically any lens that fits.
  37. #37
    Feb 2011
    Eads, Tennessee
    852
    To add to what Graham has said the DB/DB+ and a MFDB can accommodate any wide angle lens as long as the lens is in a '0' copal lens mount. My 35mm XL in Alpa mount was not able to reach infinity due to the extra spacing of the helical. I removed it from the Alpa mount and mounted it in a '0' copal lensplate and all is well. I would also be very leery of using any of the Alpa/Arca lenses in their native mounts with the Cambo adapters due to the weight distribution being placed way forward on the front standard. For me, that's just asking for trouble as this places an extra strain on the front tilt mechanism. It is much better to just remove those lenses from their native mounts and mount them in a Cambo '0' copal lensplate. The weight is now equalized front to back and it will be much easier to reach infinity with the very wide lenses. This, of course, assumes that the Actus would be used as the main camera. My STC is sitting on a shelf as I much prefer to use my Actus and I get yaw free tilt/swing and combination tilt/swing with my 35XL and other lenses mounted in Cambo lensplate.
    Victor
  38. #38
    Irvine, CA
    223
    22
    Quote Originally Posted by vjbelle View Post
    To add to what Graham has said the DB/DB+ and a MFDB ....
    ...My STC is sitting on a shelf as I much prefer to use my Actus and I get yaw free tilt/swing and combination tilt/swing with my 35XL and other lenses mounted in Cambo lensplate.
    Victor
    Hi Victor
    What MFDB are you using with the Actus DB? And what manner of focusing?
    jim
  39. #39
    Feb 2011
    Eads, Tennessee
    852
    I have used three different backs with my Actus..... An IQ180, Leafe/Credo 50 and now an IQ3-100. All were/are focused with live view. Very easy with CMOS. The IQ180 is much more difficult to focus with but it can be accomplished. I would make a rough focus with live view and then take a quick image and check at 100% on the back to see where my focus point was. At that point it was very easy to make small adjustments and perhaps a couple more practice images to nail focus.
    Victor
  40. #40
    May 2014
    82
    will the actus work with the hasselblad 1xd?
    best m
    [ no picture ]
  41. #41
    Jul 2016
    44
    best m
    No it will not the x1d does not have a shutter. Nor does it have a method to talk to the shutter on a technical camera.
  42. #42
    Feb 2009
    Scottsdale, AZ
    423
    Quote Originally Posted by Boinger View Post
    I'm not looking to buy an X1D any time soon, mind you, but its lack of a shutter isn't necessarily fatal for my purposes -- I photograph mostly at night and use long enough exposures that I time them with a stopwatch -- provided, of course, that there is some way to make it start and stop capturing an image on demand.
    Does anybody know if the camera will work without a lens attached or is there an interlock mechanism that prevents that?
    Right now, I photograph with a combination of a Sony RX1 and an A7R with adapted lenses on a modified view camera. But if the X1D will work without a lens attached (and for the record, I'm guessing that it won't), I potentially can foresee replacing both of them with a single X1D and lens at some point down the road.
  43. #43
    Jul 2016
    44
    Quote Originally Posted by Audii-Dudii View Post
    That was my thoughts initially as well. I talked to the hasselblad rep at launch and from what i understand it needs a lens attached.
