Anyone know if the Leaf Credo 60 uses micro lenses? It is advertised as ideal for technical cameras and I've heard it said among photographers that Leaf Credo is well-suited for such use. Just wondering why, and lack of micro-lenses seems a possible reason. Thanks.
doug:
could you point out the differences between a Credo and a Phase?
So from what Torger says, the hope is for CCD to live long enough to see BSI. Interesting.
The actual color loss on the 50MP Sony sensor due to Crosstalk IMO is minimal up to about 12mm of shift. I was very surprised to see this in testing I did. The amount of color/sat loss before the LCC is quite a bit, but C1 did an AMAZING job of getting it back within reason. In fact with the testing I did with the 40mm Rodie, C1 actually corrected the shifts on the 50MP back better than it does on my 260. And I did test this on a pure blue sky with a 28mm, 40mm and 60mm. The 50mp was easier to clean up on the shifts.
If and when a full frame CMOS back comes from Phase, I have concerns for I feel if they make it a great pixel pitch than the current 60MP backs, then tech camera use will not work, at least with current lenses from Rodenstock and Schenider.
Paul
Thanks, Paul. In your most recent post you mention an IQ150 in your earlier post you mention the Sony chip; so was "150" a typo and did you mean "IQ250"? Thanks again.
