"Big" news from Phase One on Monday
iiiNelson
It's almost certainly C1Pro9 due to all the recent C1Pro8 discounts and the social media clue of 9 pictures. I think I'm still good with 8 for now though unless there's a major upgraded feature list. I've been using LR6+DXO more these days in reality... When I have time to shoot.
tjv
Pentax/Leica support in C1
Is this seriously something on the table though? Not that I care–I don't own either–but that would be pretty great news.
I'd like the following features:
1: A robust and user friendly cataloguing system a la Lightroom.
2: An integrated stitching feature to keep the files 100% in C1 (again, a la Lightroom.)
3: A SPEED increase
archivue
3: A SPEED increase
4: An integrated focus stacking feature to keep the files 100%
rhern213
According to a recent post by DT, "Capture One does not support the 645Z, and support will not be added in the future." So no that's not included in their current business plan, it seems like Phase would still rather take a hit on their profits then to support the competitors users.
If they like money, I'd sure hope so. Wider MF support is a feature that's been echoed here for a while now.
strok
I would like to see a DB firmware update. Don't understand why it takes 30min to save 30min exposure file.
dougpeterson
Re: "Big" news from Phase One on Monday
It doesn't. It takes about a second to record the file. It's the dark frame that takes that time. Phase One backs automatically do a dark frame exposure. This exposure, done with the shutter closed, records the location of any hot pixels and helps characterize the noise.
The technology Phase One has developed for its dark frame is quite advanced and is one of the reasons why Phase One consistently outperforms competitive solutions in regards to long exposure quality.
- - - Updated - - -
3: A SPEED increase
Can you be more specific on these two items? What cataloging features, missing from C1, are most important to you?
Also, do you have a powerful graphics card? A strong GPU is key to C1 performance. I've found c1v8 flies with a good GPU, even with thousands of 80mp raw files.
T.Dascalos
Not Available
It could be a 1.4x TC that will allow all their lenses from 24mm up to 120mm to be used with a FF back on a view camera with movements... but I doubt that...
strok
Thank you Doug,
There's should be some way around (at list optional) to have ability to take several images with same setting and apply one black frame to all, let say if temperature of the sensor hasn't changed dramatically.
Sometimes you have 5-7 min of sunset/sunrise and every second counts. Taking 25-30 sec exposures with 25-30 sec delays sometimes killing the shot.
Cheers
dougpeterson
Thank you Doug,
Cheers
I generally agree with the idea of providing users more control, including, in this case, the option to turn off dark frame calibration. I will pass this feedback on to R+D at Phase One; you are not the first to ask for it, but every voice is counted.
That said, the back does automatically re-use dark frames if/when the conditions are similar enough to do so without sacrificing quality. With the CMOS backs for instance, the amount of heat generated during a long exposure is less, so dark frames are frequently reused even on long exposures. The ability to set an arbitrarily long exposure (not just manually-controlled-bulb) such as with the XF body helps in this regard, as the length of the exposure needs to be very close to the previous one for the dark frame to be reused.
When using one of the CMOS backs, or one of the backs with Long Exposure Mode you can also up the ISO, even during long exposures. Noise will increase slightly but results can still be excellent, and it can be worth it to gain some flexibility during quickly changing light conditions.
Thank you Doug,
Cheers
If you have a technical camera with simple sync cable then you can disable the darkframe noise reduction by setting "Camera Mode" to "Aerial" and "Shutter Latency" to "Zero". At least this trick works for every shot after the first shot each time you power on the digital back with firmware pre-IQ3 release. Not sure about the latest firmware though.
The CMOS back could benefit from this trick, as you only need to move the slider of "Single Pixel" of C1's noise reduction to 1 to eliminate 99% of the hotpixels. However the CCD backs will get drastically degraded image quality if you disable darkframe noise reduction. That's the main reason to give up the CCD backs for dedicated long exposure shots.
Nutcracker
Teasing us now
"November 30, 2015
Due to maintenace on our www.phaseone.com web site, it is currently unavailable. This may as well include activation server for Capture One.
We apologize for the inconvenience and welcome you back later.
Best regards
Team Phase One"
Hulyss Bowman
bha !! this is the kind of "big" new I wait from phase. Medium format market is around 5000 Units per year around the whole world. With the venue of the 645 (z), the new sony sensors + the crisis, those 5000 units might have hard time to be sold.
Phase One is clever because of Capture one, very valuable asset. Going 24x36 might be a good thing for such a brand.
Just my two cents.
I would just applaud if they come with a 24x36 body.
P.S: If canon really bought Phase One, I will accept a fine bottle of wine.
