Results 1 to 11 of 11
Thread: Anyone use an HDMI screen instead of LV with XF+IQ100?
    May 2012
    1,751
    Perhaps Capture Pilot with iPhone works, but wanted to know which if any HDMI screens work best and how do you fix them on your tripod? Also what size seems about right? I am sure I have missed some questions, but you must get the idea, should I try one? TIA
    Senior Member Jamgolf's Avatar
    Sep 2013
    North Texas
    375
    Re: Anyone use an HDMI screen instead of LV with XF+IQ100?
    In post #18 of this thread Ken mentioned he uses SmallHD with side finder.
    Sounds like an option that might interest you.
    Cheers!
    IQ3 100 H Cambo 1200 Rodenstock 23,32,90 Zeiss 350SA
    UnTroubled Land
    Aug 2008
    Carmel/Tucson
    2,218
    See, 5-inch, Full HD on-camera monitors with brilliant displays and a desirable form factor.
    Also available at Dante's store, B&H. SmallHD 5" 501 hdmi monitor works great paired with the Sidefinder. Although the larger real estate of the 7" monitor is great (we had both the 5" and 7" Small HD monitors at our last CI in Carmel), the 5" is plenty good enough, and when considering portability and the Sidefinder option, it was a no-brainer for me.
    If you need the power of C1 Pro, then tethering via USB3 is the best option. And if on location, the Surface Pro works great.
    I used my Surface Pro clamp endeavors to come up with what I think is the easiest, most compact, and relatively inexpensive option to attach my SmallHD monitor and Sidefinder to my tripod. I attach a AS quick release plate to the Sidefinder. A Manfrotto nanoclamp attaches to the tripod leg. I use gaffers tape on the leg for scuff protection and added grip. Giottos MH1304 ballhead (RRS BH25 would be stronger), and a AS compatible lever clamp on top. Manfrotto clamp just works on a RRS 3 series TVC tripod leg.
    kenName:  IMG_20160727_145754604_HDR.jpg
    May 2012
    1,751
    Ken
    Sounds like you've got it dialed in for sure. I was looking at a new Ikan 7" 4K monitor which has focus peaking (besides the camera), many controls and thought if I wanted to magnify a portion of an image I would just use my Hoodman loupe which I always use in any event just in case monitor glare was a problem. This is a new item at B&H and not yet on their list of monitors as yet. Maybe a 7" is overkill, but I do suffer from bad eyesight. Any thoughts? TIA
    2,546
    The Clamp is great but I would recommend a longer Noga arm and quick releases
    noga | B&H Photo Video
    Noga Cine Arm & Cine Lock Kit 2 NF14CA-CL2 B&H Photo Video
    Best monitor
    Gratical Eye SDI EVF - Zacuto USA
    Take your pick very stable and fast to dissemble and store.
    Bob
    Aug 2008
    Carmel/Tucson
    2,218
    The SmallHD has focus peaking as well. You can attach up to two batteries---same type used by the Canon 5D camera, which makes it easy to maintain with generic inexpensive replacements from Wasabi, available at Amazon---that other official Dante Store.
    Vancouver, WA
    5,485
    542
    All I would add, since this is dantes forum, is that if you're invested in the IQ3100 you shouldn't go cheap on a connected display. The smallHD devices are excellent.
    i tried the wireless option too and was very impressed. When (not if ... Ken/Don ) I eventually get an iq3 100 for myself (vs using someone else's), I'll be getting the smallHD 501 & viewfinder although I know that some of the time the iPad/iPhone will do just fine.
    Last edited by GrahamWelland; 28th July 2016 at 22:17. Reason: corrected apple's corrections
    Nov 2012
    UK
    112
    19
    Apologies if this is a dumb question but why not simply mount a 501 on the camera hot or cold shoe and connect via HDMI ? I'm thinking XF or Rm3di and an IQ-3100. (There is an A-S cold shoe adapter for the Rm3di).
    Does the Sidefinder simply give better viewing in bright light and a variety of other mounting options ?
    Smallhd's videos tend to assume a video use case and dealers here don't seem to have demo stock.
    Thanks.
    Aug 2008
    Carmel/Tucson
    2,218
    You certainly could attach the 501 SmallHD to the hotshoe----but being *ahem* height challenged, this would place the monitor slightly higher than optimal for me, though it could be angled downward. Matter of preference really. But the real advantage is being able to place and use the Sidefinder in a more accessible position. The Sidefinder basically allows avoiding glare which is the achilles heel to any device monitor in bright conditions.
    There are many different options to attaching the SmallHD, many of which are seen/listed on the SmallHD website and videos. The best one is simply what works best with your rig!
    Ken
    www.houseoflandscapes.com
    www.kendoophotography.com
    www.carmelfineartprinting.com
    Vancouver, WA
    5,485
    542
    You certainly could attach the 501 SmallHD to the hotshoe----but being *ahem* height challenged, this would place the monitor slightly higher than optimal for me ...
    Ken
    Ken, it's ok, we all have these challenges ... I'm not too proud to go for some vertical enhancement at times. My solution is the Pelican 1510
    Attached Thumbnails Attached Thumbnails Click image for larger version.
    Tucson/Carmel/Jackson Hole
    4,245
    I use mine as a chair all the time
    Don Libby
    Iron Creek Photography
    Blog
    Tucson AZ
