Results 1 to 13 of 13
Thread: XF and 120mm Macro MF issue?
    Jul 2008
    North Sweden
    1,159
    Morning all.
    I have just received a 120mm Macro MF lens, mounted it on the XF and I get the following..
    I also get this...
    I have tried the normal stuff, cleaned the contacts on the lens, removed batteries and restarted etc. All my other lenses are working fine. I have emailed my dealer but I believe he's on holiday this week so a quick question to those of you who may have seen or experienced this before? Is the lens likely to be dead or something else I am overlooking? I contacted the dealer I bought the lens from and they said it was checked as working so before I return it, just thought I'd ask, it may be something simple!
    Thanks in advance.
    Mat
    Jul 2008
    North Sweden
    1,159
    Re: XF and 120mm Macro MF issue?
    Got an answer, just in case anyone has a similar issue in the future!
    Although it was sold as 16 bit, it is the older 4 bit version which can be an issue on the XF and would require an update to the circuit board to work properly. I will just return it!
    Mat
    http://matrichardson.com/
    May 2012
    1,768
    On a tutorial I heard that lenses prior to 2008 (might have the year wrong, but somewhere around that) will not transmit data to the XF.
    It was either a Phase video or Doug's focus stacking video.
    Jul 2008
    North Sweden
    1,159
    I believe that the older 120 with an aperture ring will work if used under the manual lens setting, but as this one has no aperture ring, it requires communication with the body. Apparently there are some that work and some that don't, I can send it off to get the electronics updated but hardly seems worth the hassle for such a cheap lens.
    Cheers
    Mat
    Jul 2016
    Richmond Va
    52
    I believe the lenses that were updated for digital have an extra 2 pin connectors on the mount.
    Jul 2008
    North Sweden
    1,159
    Yes, I believe you are correct, extra pins for the 16 bit D version which works. According to Phase, there was a problem with the XF and 4 bit lenses which was apparently solved in the most recent firmware update but that's not the case for the lens I have here. Shame, it's in excellent condition!
    Mat
    Member Oamkumar's Avatar
    Jun 2012
    Kochi, India
    88
    I had issues with MF version of 120D lens when it is attached to the DF+ body. Changed 3 lenses and got the same issue with all of them. Aparture ring sometimes get stuck and will not go back. (not always, but especially when I use live view.). Finally I bought the AF version and so far no probs. Compared MF and AF versions and AF is better in the corners. Both are almost equal in the centre.
    Phaseone DF+, Leaf Credo 60
    www.oamkumarthottungal.com
    Member ejpeiker's Avatar
    Aug 2016
    Chandler, Arizona, USA
    64
    I can't for the life of me find that Status screen on my XF - how did you get to that screen? It doesn't even show up in Phase One's own published menu tree for the camera.
    Jul 2008
    North Sweden
    1,159
    I don't think the screen is accessible normally, I think it's just part of the internal checking process on start up and only displays if there is an issue. I didn't access it from the camera, it just appeared.
    Mat
    Aug 2016
    64
    Ah OK, thought I was losing my mind! Thanks
    May 2012
    1,768
    I can't remember exactly, but I think holding down the battery check can give you that screen.
    Aug 2016
    64
    Quote Originally Posted by algrove View Post
    Ah, actually it's a tap of the battery icon that brings up that screen. Cool, thanks for helping me figure this out!
