Results 1 to 5 of 5
Thread: Mamiya RZ and P+ series back on a non-rotating plate
    Sep 2016
    31
    Hi All,
    First post here, I am considering adding a P+ series digital back to my Mamiya RZ67proII (nond) system. I've been offered a mint condition P65+ in V mount which means that it won't rotate on the camera (just like regular film backs) but needs to be removed and attached again in vertical/horizontal. I shoot portrait mostly and do switch positions frequently. Do you think it will be a big deal? Has anyone been using this combo. Just a bit worried about potential dust / dirt / damage while switching the positions rather than switching to R on the body and rotating the back without removal.
    Best,
    Pat
    Aug 2013
    Tokyo
    83
    Re: Mamiya RZ and P+ series back on a non-rotating plate
    Can't quite comment on convenience as I am not aware of the nature of your shooting.
    I am using IQ160 on RZ67ProIID with rotating plate and its gaps have proven to be an easy access path for lint and microdust.
    Rather annoying, but nothing a sensor cleaning kit won't take care of.
    And if you are happy with maximum 4 seconds exposure time with Dalsa back on RZ - I don't see any problems.
    Sep 2016
    31
    Thanks for your input. Dust does not scare me one bit, the thought of removing the back for horizontal / vertical placement does; easy to scratch or damage during a shoot (fashion/portrait). The ability to rotate the back on the body with a simple switch is probably one of RZ's favourite features for me as well. I've decided against the idea of V mount P65+ and I've found a Mamiya mount instead.
    All I need to find now is a HX701 0r 705 adapter.
    Thanks again!
    Quote Originally Posted by Krosavcheg View Post
    Aug 2013
    Tokyo
    83
    Quote Originally Posted by robdeszan View Post
    Thanks again!
    No problem.
    Indeed, it's better to eliminate the risk.
    HX701 should be relatively easy to find, I believe both Digital Transitions, and Captureintegration stock them.
    Good Luck and Best Wishes
    Sep 2016
    31
    Quick update,
    having now used a Mamiya mount back that rotates on a camera, I am really glad I did not go for the V mount. You could damage it veeeery easily.
    Pat
