malmac
I am currently using an IQ180 and a 645DF - keep thinking about scraping together the cash to buy an XF to run with the IQ180.
I have looked through the latest manual for the XF and been able to determine that some functions will not work, for instance inability to change the ISO from the camera body - with an IQ180 it has to be changed on the back.
Obviously I am not getting an electronic shutter because that is fundamentally a back driven function, as is the heat sensor in later model backs.
It seems that powershare is not a function that the IQW180 gets to utilise.
So I have been trying to make a list of functions that won't work with the IQ180 - unfortunately I have not been able to find a table that informs potential customes - if you have this back, this works and that doesn't so to speak.
What I have found so far.
powershare between camera and back
ISO adjustment is not activated by rear dial on camera
camera controls do not show on IQ180 back
electronic shutter only on IQ3 100MP back
camera set up icon on back does not show up
turn on camera and back from back ????????
histogram on camera top screen ?????
WiFi (IQ2 and IQ3 only)
HDMI export (IQ3 only)
sensor temp tool
exposure calculator tool
exposure zone tool
rename custom setup of camera using IQ back????
If you are running an IQ180/160/140 on the XF would you be so good as to add to the list if I have overlooked an XF camera function that should be on the list?
Thanks in advance
Mal
sensor temp tool
exposure zone tool
Thanks in advance
Mal
