Phocus 3.1 Released
  • Thread starter Deleted member 7792
  • Start date
modator
Phocus v3.1 available for Mac and PC:
Hasselblad
No problems (so far) with Mac OS Sierra.
Joe
Hi Joe, can You check this three:
top menù: [window] / [Camera Configuration] --->here phocus get stuck
select an image...
top menù: [window] / [Color Calibration] ---> here I see weird color point instead of image...
Left menu: [Capture] / Capture sequencer / set pre delay, deleting the 0 (default) ---> here I get error...
Let me know, I don't know if it's an error in my config ! :banghead:
Best regards, Domenico.
modator
Indeed. I checked the first two and they are bugs as you have determined. I don't have my camera yet so I can't check the third.
Joe
Hi Joe,
it's possible to check also without a camera,, on capture sequencer simply going on the setup of pre-delay, simply deleting the default 0 cause the error.
I've cross checked it on another machine, same issue.
Best , Domenico.
Phocus on my iMac goes into a spin shortly after launch on Sierra. Worked, and works, under the previous Mac OS. No improvement after updating Phocus to 3.1 and still not working under Sierra 10.12.1. Lightroom is my friend.
/Eric
CSP
/Eric
i would try to delete following files, maybe this helps
/User//Library/Caches/dk.hasselblad.phocus
/User//Library/ApplicationSupport/dk.hasselblad.phocus
/User//Library/Application Support/Phocus
/User//Library/Preferences/dk.hasselblad.phocus.plist
jotloob
/Eric
I can't run SIERRA on my MAC BOOK PRO . It is obviously too old .
Also , PHOCUS 3.1 Keystone correction does show speed trouble . The graphic card seems to be too slow either .
So I am back to PHOCUS 3.03 again and have PHOCUS 3.1 on my MAC PRO only , where it runs fine .
CSP,
Thanks! Works. I deleted Phocus 3.1, restarted and installed Phocus again for good measure.
/Eric
sortvitt
Camera Configuration does not work for H6-100c - says 'unknown camera, only H5 supported'... I'm on Mac and.latest fw. Any workaround to configure buttons on H6?
bab
What does the manual instructed you to do ? If there's instructions in the manual it should work with the new Phocus if not then there some problem with the Phocus you have installed
