I have a Credo 50 and shoot architecture with several Rodenstock lenses. I like to dabble in landscapes as well, but I'm a rank amateur in this realm so I'm sure someone else can chime in. The 32HR is a fantastic wide angle lens but well over the budget you quoted. It's also physically massive and a lot to carry around as a landscape lens. The 40HR might be a better pick in terms of size. It's less expensive than the 32HR and easier to filter. The 40HR is still twice your budget but I think it's a versatile focal length and a good lens to start a tech camera kit with. I don't own the 40HR but I do have the similar 50HR - that might just be a little too long for your needs if you prefer wides.I shoot landscape mostly, prefer wide angle. would like to be able to stitch. Budget is aprox $3500 per lens
If you were shooting with Arca then I'd definitely recommend the 23HR, which for me is a must-have lens for 44x33mm sensors. It's even wider than the 32HR on a fullframe 645 sensor when you do single exposure (e.g. long exposure) while stitching is not practical. With Cambo you can't tilt it though.I shoot landscape mostly, prefer wide angle. would like to be able to stitch. Budget is aprox $3500 per lens
