dougpeterson
"You can use our Multi-Pop / Long Exposure Device with a Phase One digital back"
Doug,
Have you tried this? I have never been able to use the B setting on my Contax 645 with a P45 because of some error between the electronics in the Contax grip and the P45. 32 seconds on auto is the longest I have ever been able to utilize. Does the multi-pop device counteract this?
The device works by fully decoupling the body and back from eachother so that you can actuate the shutter in whatever way, and as many times, as you would like. The digital back becomes just like a traditional film back set on multi-exposure (no advance after shutter release); you turn it on (remove the dark slide) and turn it off (put in the dark slide).Doug, does the multi-pop/long exposure device work with the mechanical release socket? I don't have a heavy-duty tripod yet (I have a Manfrotto 055C and was planning to test it to see how it goes), but I just ordered a BH-55, so I guess the head is covered. I might pick up a Berlebach tripod if the 055C is not good enough. The workflow is something I plan to learn
So yes, your mechanical release socket would work fine. And yes, it does allow any mix/match of shutter releases and shutter durations.
Or another way of thinking about it: Whatever you can do with no back attached you can do with a P or P+ back and this device.
In general the swap time is very quick. There were a few customers who had to wait unusually long after there was a seachange of users switching to the Mamiya mount after Phase One and Mamiya began their partnership. You keep the back which is being swapped until the replacement is ready.Is that your P25+, by the way? I have the feeling from reading your recent posts that you are considering the P45+. Anyway, I understand that Phase doesn't actually change mounts, but gets the back on hand, and waits for one with the correct mount to come in, and then swaps them. I am not sure I would want to wait around for that, as for the less common Contax (in the Phase/Mamiya world) it could take some time. I have heard of people waiting months...
Doug Peterson (e-mail Me)
__________________
Phase One, Canon, Apple, Profoto, Eizo & More
National: 877.217.9870 | Cell: 740.707.2183
Newsletter: Read Latest or Sign Up
