Phase One AF 28mm lens
I received a 28mm lens from ebay bid but my DF+ is not here till next week. I can only check the lens visually and by feel. Everything seems okay but I see the AF barrel is so easy to turn. Is that normal for phase one lenses? I only have experience with Nikon AF lenses so far which seems a bit stiffer.
Thanks,
Steve
GrahamWelland
Subscriber & Workshop Member
About as firm as a limp handshake until you put them on a body in AF mode I'm afraid. It shouldn't be super loose though, just AF lens loose.
Just realized it was a push pull AF/MF switch. It was in the MF mode with no marking and really loose. Everything turned out fine with AF working. Thanks for your help!
