Page 31 of 58 FirstFirst ... 21 29 30 31 32 33 41 ... LastLast
Results 1,501 to 1,550 of 2865
Thread: Sigma DP2 Merrill shots
  1. #1501
    Jan 2013
    North of Copenhagen, Denmark
    117
    Re: Sigma DP2 Merrill shots
    Quote Originally Posted by ustein View Post
    Thank you very much for showing this.
    I have just got the Sigma viewfinder - the missing focus-point is not a problem for me, you can learn that,
    .... but there is no dioptri, and that is a problem for me, even I do not wear glasses generel, only for reading, but I have dioptri in all my other cameras, and I can see now how important that is = I do not like to look at a blurred frame without dioptri, so I think I will return the Sigma-viewfinder og perhaps use your solution.
  2. #1502
    Aug 2010
    927
    First shot with the close up lens on the DP2m
  3. #1503
    Feb 2013
    860
    I am not sure if a viewfinder w/o diopter adjustment will work for me either.
    On any other cameras I use I have them, and I always need to dial them in.
    I may just have to try one w fixed adjustment and find out if it works for me.
    If it doesn't I will probably go w Ustein's solution.
    I wonder if an shoe-mounted EVF from another manufacturer would work on the Sigma ?
    When you install the shoe-mounted Sigma flash does anyone know if it just makes a connection ? Or does it pull a voltage off there as well ?
    Having a shoe-mounted EVF would be an elegant solution.
  4. #1504
    Feb 2013
    Stazzema(LU), Italy
    29
    Hello
    could anybody help me with some Dp2 Merrill X3F files to download?
    I was looking through Google but all the links i found, some in this thread too, are expired or empty Dropbox folders.
    Thank you very much! ciao!
  5. #1505
    Jan 2013
    Denver, CO
    38
    Quote Originally Posted by The Ute View Post
    ....I wonder if an shoe-mounted EVF from another manufacturer would work on the Sigma ?
    Shoe mounted EVF's all rely on the camera sending up video to the EVF. There's no way it would work on any other camera, even a different brand that also had a shoe-mounted EVF.
    If you must have an EVF get a rear LCD magnifier and use the rear screen as an EVF. Then you can hold the camera up to your face for greater stability.
  6. #1506
    Feb 2013
    860
    "Shoe mounted EVF's all rely on the camera sending up video to the EVF. There's no way it would work on any other camera, even a different brand that also had a shoe-mounted EVF.
    If you must have an EVF get a rear LCD magnifier and use the rear screen as an EVF. Then you can hold the camera up to your face for greater stability."
    Thanks. I was just wondering is all.
    I will probably do as you suggested at some point. Just seeking info.
    And I must have a better solution because using the LCD in bright sunlight does not work very well IMO.
    It does not allow for precise framing of images and that can be a problem.
    Ustein posted his setup and that is a possibility. It seems a bit cumbersome to me.
    Perhaps that is because I have not tried it yet.
    Guess nothing will be perfect. So if that's the best way to go then so be it.
  7. #1507
    Apr 2009
    83
    Quote Originally Posted by MarcoPampaloni View Post
    Hello
    Marco,
    Perhaps not the best (I only had a borrowed camera), but this should give you an idea of the camera and software...
    kofronphotography.com/downloads/sdim0037.x3f
    kofronphotography.com/downloads/sdim0038.x3f
    Jim
  8. #1508
    Aug 2010
    927
  9. #1509
    Feb 2013
    Stazzema(LU), Italy
    29
    Quote Originally Posted by Kofronj View Post
    Marco,
    Jim
    thank you very much Jim!
  10. #1510
    Aug 2010
    927
    sorry guys I made a change in my photo web host security and it deleted the above pic ... here it is again
  11. #1511
    Senior Member W.Utsch's Avatar
    Oct 2012
    Heidelberg, Germany
    897
    SPP 5.5 BW Test:
    Converted with SPP 5.5
    SDIM1499-15. Februar 2013-130215-ISO 100-39.jpg by W.Utsch, on Flickr
    Converted with NIK SE 2
    You have to look at 100% via Flickr to see the differences
  12. #1512
    Senior Member biglouis's Avatar
    May 2009
    2,001
    Thanks to the incredible resolution of the DP2M I can now definitively state that I have a male squirrel hanging around for the occasional nuts we put out for him...
    ...shot through a window, btw.
    My new book "Whitechapel in 50 BUildings", Flikr Stream, www.louisberk.com
    Likes 9 Member(s) liked this post
  13. #1513
    Oct 2012
    Heidelberg, Germany
    897
    SPP 5.5 Monochrome my first impressions:
    Based on quite a few BW conversions with SPP 5.5 and LR+NIK SE 2 and prints in A2 (E 3800 AWB-mode).
    The SPP conversions are an improvement compared to SE2. The grey tones are finer, more subtle converted. The image is homogen and very sharp with no grain.
    SE2 converts more coarse or rough.
    We should compare to the output of the Leica MM.
    The software is on my iMac (27 newest gen.) with 10.8.2 very unstable. It crashes often when you change from BW mode back to colormode or if you doing adjustments in BW.
    I had conversions (save as tiff) that came out strange, i had to redo these.
    I hope this gets fixed soon. Otherwise i like SPP, the Monochrome mode is a good and welcomed improvement.
    Looking forward to read your impressions.
    Werner
  14. #1514
    Jan 2013
    117
    Quote Originally Posted by W.Utsch View Post
    Werner
    Are we talking about just a conversion using the default setting in SE 2 ? - If so ?: The strenght of SE2 is the many ways to change the output= There are fantastic many possibilities, and that is why I think it is at another level.
  15. #1515
    Oct 2012
    Heidelberg, Germany
    897
    No, i optimized in SE2 the conversion.
    SPP converts on the RAW level.
  16. #1516
    Feb 2013
    Stazzema(LU), Italy
    29
    Unfortunatly i think i am not going to buy the Sigma, i was almost ready for it, but today i installed SPP 5.5 on my iMac running OS 10.7.5 with 3.06 ghz intel core 2 duo and 8gb Ram and it's simply impossible to work with it. When i touch some sliders ( especially white balance and NR ) i have to wait for about 10 seconds to see the effects and i always got the Apple OS coloured rotating wheel which tells me that the program is going so slow and freezing. Also the same in monochrom mode, when i start to change the RGB values same story.
    Is my Imac too old and weak?
  17. #1517
    Feb 2013
    Scottsdale AZ USA
    119
    This makes me sad for you, Marco. I have the 5.4 running flawlessly on a 3 year old iMac (10.8.2) and 5.5 running flawlessly on a new MacBook Air (10.8.2). Don't give up!
  18. #1518
    Jan 2013
    117
    I also run 5.4 without any problems at all - though pc, I have read that MAC.s had some problems with the earlier Sigma Pro Photo - perhaps more problems than PC.s ? - but it should have been fixed - at least in 5.4
    I was not aware there is a 5.5 ?
  19. #1519
    Jan 2013
    117
    What sliders/features did you use in SE2 ?
  20. #1520
    Oct 2012
    Heidelberg, Germany
    897
    5.4 runs good on my MACs. 5.5, no problems with speed but frequent crashes.
    Want to add: If you convert to BW in SPP you can still edit the Tiffs in LR and Silver Efex with all effects etc..
    But the basic BW conversion in SPP is, IMO, better then the conversion from the color file in LR et al. Look at the to BWs i posted above (1511) in 100%.
  21. #1521
    Aug 2010
    927
    Marco , not to post old news but you may not of seen this before. Many had issues with 5.5 on their Mac's till they uninstalled 5.4. I run a 10.7.5 Mac and have only seen what the above poster wrote about doing a monochrome then switching back it is sometimes shutting the program down.
    Marco did you uninstall 5.4?
  22. #1522
    Jan 2013
    117
    I should add: I run SSP on t w o pc.s - 5.4 - no problems at any of the pc.s (W7). Have never had a crash, and it is reasonable fast.
  23. #1523
    Oct 2012
    Heidelberg, Germany
    897
    @Kyndel:
    Used a neutral preset and the brightness, contrast adjustments as well as color filters in SE2. Tried to optimize the file.
  24. #1524
    Jan 2013
    117
    W. Utsch
    That sounds fine to do, but I have downloaded a course from Jason Odell - not yet had time to follow it, but I can see, that there are endless possibilities, e.g. red,yellow-filters etc - if you know how - I do not - ......yet
  25. #1525
    Feb 2013
    Stazzema(LU), Italy
    29
    First of all thank you for your help and suggestions.
    Well i didn't uninstall SPP 5.4 simply because i didn't have it before, i have never used any Sigma camera and SPP until now, so yesterday for the first time i downloaded SPP 5.5 and installed it to try some x3f since i was planning to buy a Dp2 merrill. So, on my iMac the very first SPP to run is this latest one, the 5.5.
    Maybe i could try to uninstall this latest version, 5.5, and try with the older one ? But this would be bad since i'd like to use the monochrome panel...anywway i will try later again and see if it's still so hard to use it for me.
  26. #1526
    Jan 2013
    Denver, CO
    38
    It really should not be that slow. Changes to the sliders are instant on my mac also.
    How much RAM do you have? That may be the issue.
  27. #1527
    Feb 2013
    Stazzema(LU), Italy
    29
    I have 8 GB RAM.
    Changes to the sliders: some are istant ( like exposure, contrast, fill ligh and so on ) other are so slow, like 10, 15 seconds with everything frozen, this happens with NR sliders, colour and WB sliders.
  28. #1528
    Feb 2013
    Stazzema(LU), Italy
    29
    I did some other tests.
    So, main problems come when i switch to full res mode and work 100% on screen with sharpening and NR sliders. Anyway when i am in full res mode also other controls are slow sometimes, like WB and colour settings. This doesn't happen when i am in "normal" mode. Just a questione: when i am in full res mode can't i go back to normal mode? i try to click on the full res icon again but nothing happens, is this normal ?
    I managed to work in a decent manner by working in normal mode and only at the end of the workflow switch to full res mode for 100% on screen adjustments. But, of course, i would like to work always with full res mode, if possible!
    Anyway Dp2 merrill files are amazing, if i can manage to resolve these software problems i will buy one for sure..now i go on searching on the web for more x3f files to try and have fun with.
    Forgot to say that i set up my preferences to work in Prophoto mode, but i am quite sure this isn't why i am having those problems i told about before.
    Thank you guys and sorry for being a bit boring with this stuff
  29. #1529
    Feb 2013
    860
    Marco-
    For Mac users there is another option to SPP.
    I am giving you the link below:
    Iridient Digital
    This raw converter works w Apple products and X3F files.
    I do not use it because I have a Windows machine.
    They have a trial version. Check it out. See if it helps.
  30. #1530
    Feb 2013
    Stazzema(LU), Italy
    29
    Thanks a lot, i will try it for sure.
  31. #1531
    Feb 2013
    860
    Marco-
    You're welcome.
    If you do please let us know what you thought.
  32. #1532
    Jan 2013
    Denver, CO
    38
    Not sure if that is normal.
    That would explain your slowdown, full res mode is slow (which is why it's a mode and not up full time). For every change it's doing a full conversion of the whole image.
    Some adjustments should not be that slow in full res mode, like exposure - usually only adjusting things like noise reduction causes significant slowdowns. I'll have to review.
    You might want to try working in some of the other modes and see if it helps.
  33. #1533
    May 2010
    168
    I have 8 GB RAM.
    If you're trying to do this with a full res image and 8 GB of RAM your iMac is caching the undo to the hard drive. It's bound to be very slow and if your drive is fragmented that would cause most apps to crash.
  34. #1534
    May 2009
    2,001
    Unusual bulb vases - my wife is an authority on forcing bulbs and she normally takes all her own photographs using my discarded Panasonic LX5. However now and then she asks for my help.
  35. #1535
    Oct 2012
    Heidelberg, Germany
    897
    More BW:
    The more i use the feature, the more i like it. Made more tests (pint and screen), converting pics i had converted before with NIK SE2, now with SPP.
    The SPP conversion is clearly better.
  36. #1536
    Feb 2013
    Stazzema(LU), Italy
    29
    Thanks a lot again.
    For now best thing is to process in normal mode and switch to full res only when i really need it for 100% adjustments. Then, it would be very useful to be able to come back to normal mode from full res mode, i still can't do it.
  37. #1537
    DSG
    Quote Originally Posted by Jorgen Udvang View Post
    This is as if somebody invented an entirely new kind of imaging technology.
    They have, its called the Foveon X3 sensor!
  38. #1538
    Feb 2013
    860
    If they ever go to a FF sensor the lines will be around the block.
    Or at least they should be IMO.
    Can you imagine what that would be like ?
    OMG
  39. #1539
    Feb 2013
    5
    OMG
    It would be bigger and heavier. Files would be bigger then the 85mb now. The resolution is almost more then I can use now unless I'm printing bigger than 20x30.
  40. #1540
    Feb 2013
    Stazzema(LU), Italy
    29
    I tried the Iridient software, i have no problems with it: fast and smooth, even at 100% view. Problem is that x3f files look worst with it, especially when i go 100% view. So i have to keep on trying with SPP
  41. #1541
    Feb 2013
    860
    "It would be bigger and heavier. Files would be bigger then the 85mb now. The resolution is almost more then I can use now unless I'm printing bigger than 20x30."
    It wouldn't be much bigger nor signifcantly heavier.
    And one can never have enough resolution IMO. The more the better as far as I'm concerned.
  42. #1542
    Feb 2013
    860
    "I tried the Iridient software, i have no problems with it: fast and smooth, even at 100% view. Problem is that x3f files look worst with it, especially when i go 100% view. So i have to keep on trying with SPP"
    Sorry to hear that. The faster and smoother part sounded good.
    Maybe you need to work w it more ?
  43. #1543
    Feb 2013
    Stazzema(LU), Italy
    29
    Maybe, yes. But the difference in detail rendering is very big, anyway i will try for sure again.
  44. #1544
    Feb 2013
    860
    Just a heads up in case anyone is looking for a DP1 or DP2.
    47th St photo in NY is selling either brand new for $799 w free shipping.
  45. #1545
    Mar 2008
    Santa Monica CA
    83
    Santa Monica Beach
    more first walkaround with DP2 at antara.smugmug.com in Photography galleries
  46. #1546
    Aug 2010
    927
    heres a couple conversions from today in SPP5.5
  47. #1547
    Senior Member ecsh's Avatar
    Jun 2009
    Tax State
    547
    These people have without a doubt the worst online store i have ever had the displeasure to use. Even after typing in the camera, it will not come up. Terrible.
  48. #1548
    Feb 2013
    860
    "These people have without a doubt the worst online store i have ever had the displeasure to use. Even after typing in the camera, it will not come up. Terrible. "
    You'll find their storefront on Ebay.
    Just type in either Sigma DP2 Merrill, or Sigma DP1 Merrill in the search field on Ebay.
    You'll see them listed there for $799 w shipping.
    Hope that helps.
  49. #1549
    Jun 2009
    Tax State
    547
    Thanks, i will try that. I did a Google for them and tried their regular site, which i will now avoid.
  50. #1550
    Apr 2009
    83
    Marco (and anyone having issues with SPP 5 on a Mac).
    Try the following. Go to User>>Library>>Preferences and delete the com.sigmaphoto.photopro.plist file (it will be recreated on the next launch). Also go into User>>Library>>Application Support>>SIGMA PhotoPro and delete any files that might be in that folder (you may not have this folder—I've been using Sigma Photo Pro since v 2.1, and I think this folder has been deprecated).
    I had the same issues with crashing when switching between modes. Doing this eliminated it, and I processed a bunch of SD15 files without a glitch this weekend.
    Jim
