DP Merrill accessories
Dryce
I wish to do landscapes anong others with the cameras by stitching and would appreciate if any have a suggestion for a good pano head.
I use Sunwayfoto L bracket to attach the camera vertically to a cheap macro rail via an arca clamp - and then mount that on a lightweight tripod. I've ben thinking of augmenting it with a rotator with clickstops to make things a bit quicker.
I have the AEL button configured to lock focus and exposure.
However on a recent trip I was taking landscape panos from high viewpoints using the DP2M and DP3M by handholding - I think the DPMs were made
for this - the detail is astounding.
The Ute
That's a piece of ultimate gear....:rolleyes:
With all you spend it should be like chump change.
B and H has 'em on sale for $299 w free upgraded software included.
I have been toying w the idea of getting one for a while now.
Just not sure how much I'd use it.
Haven't pulled the trigger for that reason and because I need to save my pennies for the DP1Q.
G43
Thanks... and the details edges makes it easier to stitch..;)
G43
299 is such a round figure ;)
You are putting your savings into the Quattro basket? Is it the lens issue?
The Ute
Not so much a lens "issue" as a hoped for improvement.
I seek perfection within my modest means.
I will use whatever tool gives me the best results.
If the DP1Q is that tool more than the DP1M it will be my new weapon of choice.
If not, I am quite happy sticking w the DP1M.
I'm hoping to do the try-before-you-buy w the DP1Q as I did w the DP2Q.
G43
Fair enough UTE... until everything is proven, hopefully to the best, you will know at the end.
X3inca
Well, if you count software (for Mac OS-X) as a accessories, :D.
I found a QuickLook PlugIn (X3F-Utilities V 1.51) which enables a preview on X3F-Files.
This way you can see from Finder wich picture is in the file, no need for jpeg (if this is the only reason). It still works with 10.9.4 & Merrill 2 /3 X3F RAW's - you can find it here: (Corpus Callosum Corporation) software
Greetings, X3inca.
G43
That's a cool thing.
It is quite astonishing Sigma even with the SPP6 does not show at least thumbnail images of the raw file. :loco:
G43
Thanks Dryce...
This pano gear seems pretty nice to me. I do not mind a bit of manual leveling now we are in the slow motion world of Sigma Foveon.
If someone novice Merrill fan like me would ever stumble over this thread, it makes a very comprehensive shopping list.
I am soon going to initiate some of the very useful suggestions here into my newborn Foveon photography. I'll have the cameras in hand on Friday next week.
silver92b
This is a great thread. Learned a lot here, thank you! I purchased a cheap (relatively) OVF that someone in Israel hacked for the DP2 M. It works after a fashion, much better that the screen under sun light, but no focusing, info or anything else. Kind of like shooting the R-D1 with a non-coupled lens LOL.
I also found quite by luck that the lens hoods from an old OM 35mm camera fit the DP2! I used the conical metal filter for a bit, but I'm going to try the collapsible rubber unit for now.
I just ordered an adapter VF loupe for the 3" screen it is used from Amazon, but only $79. I also just ordered a grip/frame from ebay, I hope it worksout well. The 49mm-62mm step ring is also on order so I can use the CPL filter (and ND filter) I bought for my 12-40mm F2.8 Oly lens.
