Desperately seeking help. On my Epson 7890, I'm trying to print my portfolio, double sided, with many borderless images. I'm printing on 13x19 Moab Entrada Bright 190.
The problem I'm having is, I'm getting ink marks on the reverse side of the paper (which ultimately will be printed on). They're regular marks, about /18" apart, along the long dimension of the paper, most prominently along the right side (as you're facing the printer), where the print head is. It's pretty clear to me that the borderless printing is resulting in some ink overspill, and when the print head passes over the area of overspill, that momentary pressure presses the paper against that area, leaving a mark on the underside.
Has anyone encountered and solved this? My whole portfolio is planned and built around printing 13x19. I can't simply trim off the marked area. The final trim size will be 13x18, so I need to keep the 13" dimension intact.
thank you
ethan
thank you
ethan
