focus confirmation
J
Jamesmd
just a stupid little thing , perhaps you already know or it might even come on the user guide, but I just realized that in macro manual focus you get the green dot confirming focus , never saw it before . nice .
cheers
douglasf13
Yeah, it works well, but it stays on a little long. For my camera, it works best if I focus from the minimum focus distance towards infinity, and pull the trigger immediately after the light turns on. If I start at infinity and go the other direction, I get back focus.
Unless you don't have enough light... recently I was testing a chipped MF lens and the AF confirm didn't work at all past f5.6. Also, it doesn't work with bellows unless you have a LOT of light.
gsking
The center focus point should work until F/8...or F/6.3 at least.
At least it works on the slower Sigma primes (f6.3 or f/7.1, IIRC), the beercan doubled. (f/8), and the 500 reflex (f/8)
No reason why the chipped MF lens should be any different
Maybe my issue was that the DOF in this case was ridiculously thin - 135mm @ about 6 ft. Point is, results will vary. It may work at f7 on one lens but not past f6 on another.
Could be. I need to play with it more, for what I was doing at the time focus was not especially important so I didn't spend a lot of time analyzing the issue.
