Page 2 of 2 FirstFirst 1 2
Results 51 to 52 of 52
Thread: A900/A850 firmware 2.0 is out!
  1. #51
    Jul 2009
    Re: A900/A850 firmware 2.0 is out!
    A couple from the 200mm HS APO. I shoot it at infinity over big valleys in the mountains and for 'stand off' subjects, on an A900.
  2. #52
    Senior Member pegelli's Avatar
    Dec 2010
    Quote Originally Posted by Irenaeus View Post
    Question: I use two Minolta lenses with my a900. One is the 35/2 and the other the 85/1.4 and one of them needed a focus correction to be dialed in. If I update to Firmware 2.0, am I likely to have to do that whole focus correction process all over again? If so, I'm not sure it'll be worth the hassle, as I don't own the calibration targets, etc.
    All my lens settings remained intact with the update, and focussed in exactly the same spot
    Just to be sure I have a small spreadsheet on my computer with the AF adjust settings I use for every lens I have calibrated, so in case something goes wrong (firmware update or other) I can always restore without having to redo the calibration
