4/3 and m4/3 ---> NEX adapters
Rawfa
If there was a way to control the aperture these adapters would be incredible. Can you imagine using the 20mm f1.7 on the NEX!
hot
If a have these adapters ... then I'll find a way for aperture ... for $ 0.0314159 ...
Use brain for thinking ...
douglasf13
Yeah, the real issue is that m4/3 lenses are focus by wire, so there isn't currently a way to focus them at all, whether it be manual or AF.
simonclivehughes
Wait, wait ... do simple things simple.
Hot, sometimes your posts can be infuriating! :mad: Perhaps not intentionally, but infuriating nonetheless. Please explain what you mean by this, as I know of no way to focus the m43 lenses that are focus-by-wire.
Help us out here! :D
hot
It works ... but I must make it perfect ;-)
First I have to plant my 1.000.000 flowers, cut my 6 trees into small pieces, renew my biotop ...
Using brain - you can find a simple solution ...
Today I tested it with ---> "NEX5 + Canon 50mm / 1.8 II"
