edwardkaraa
Jae, have you tried the mentioned lenses, apart from the ZA 85?
I'm a bit confused by statements like yours especially that they involve different platforms with different sensor characteristics.
The 85L is better (I don't like the word beats) than the ZA between 2.8 and 5.6. The ZA has the best performance of any 85 from WO to just below 2.8.
The 24-70 has the best performance of any equivalent zoom at all apertures except in the very extreme corners which is a very very small part of the frame. At 35mm it is sharper than any prime I have ever used.
In any case, no other brand will give you the Zeiss characteristics, so if you're after the Zeiss look, 3D and high micro contrast, as well as the sharpest look at normal printing sizes (due to high micro contrast at the right frequencies), the choice is obvious.
The 100/2.8 macro is a direct Minolta port without any updates, its a bit wooped by the Nikon 105mm VR and even the Canon 100mm Macro F2.8.
Personally I think the best in class lenses for the Sony A900 are:
85mm ZA F1.4
135mm ZA F1.8
16-35mm ZA F2.8
135mm STF F2.8/4
You're not going to find better lenses in that range for any platform. The only lens that beats the 85mm ZA F1.4 is the Canon L F1.2 85mm.
The 24-70mm F2.8 while being a good lens has much poor corners than other lenses of its class.
