Results 1 to 2 of 2
Thread: Problem with NEX 18-200 zoom
    Recently purchased the Sony 18-200 for my NEX. I can't zoom beyond 143mm. I know that is the limit at f5.6 but no setting at all will allow me to zoom up to 200mm. Any ideas please?
    Senior Member pegelli's Avatar
    Dec 2010
    Re: Problem with NEX 18-200 zoom
    Is it a problem in Exif reporting, or can't you physically turn the zoom ring past the 143 mm point? If it's the first it's a problem with the electrical contacts in the lens, if the latter something is mechanically broken. Don't know how much this helps, because for both I would return the lens (assume it's still under warrenty).
