Results 1 to 22 of 22
Thread: NEX-7 + Leica R?
    May 2009
    296
    NEX-7 + Leica R?
    Is using Leica R lenses on Nex-7 a good idea? What adapter is needed? Have you seen any images with this combo on the internet?
    Workshop Member glenerrolrd's Avatar
    Jupiter FL/Atlanta GA
    2,213
    Re: NEX-7 + Leica R?
    Jono has a nice thread on focus peaking (in the Leica area) .
    You can find the Leica M and Leica R novoflex mounts at B&H . Plus plenty of less expensive versions on ebay .
    The issues in from my perspective with R on Nex :
    1. Balance ...how well do the lenses handle on the much smaller Sony Nex bodies . The Leica M glass seems to be a better fit . However if I used the 180/2.8 APO as a reference ...the balance point is under the lens .
    2. Size ...one definite advantage of the Nex bodies is a smaller size and weight . I would tend to favor a M lens over a R lens of the same focal length.
    I did find that Novoflex is making a lens bracket that provides a forward tripod mount . Wraps around the adapter so its not perfect ... Not sure I would mount NEx body with a heavy R lens on a tripod mount attached to the camera . (its NOTMN14 @B&H).
    Godfrey's Avatar
    Jan 2009
    Near San Jose, California
    7,668
    Quote Originally Posted by lowep View Post
    Roger addressed the adapter and balance/handling, Jono's been showing photos with them on the NEX 5n that are very appealing.
    From an imaging point of view, R glass will likely perform better than M lenses, particularly with the shorter focal lengths. NEX bodies are not generally optimized for the M lenses like the Leica M8/9 or Ricoh GXR-M (although the NEX 5n does pretty well, better than the NEX 7 by all account).
    SLR short focal length designs tend to have a ray trace more similar to lenses optimized for digital sensors, so in general SLR lenses adapt better to digital capture use.
    Apr 2008
    Netherlands
    12,836
    15
    In general, no, IMO.
    The NEX-7 is feather light even compared to the simplest of the R lenses (not including an adapter!). The R primes mount, handle and perform beautifully on my SL2 as they always did.
    May 2009
    296
    So the size and weight combo of Nex-7 and Leica R lenses may be about as crazy as putting a 24MP chip in a credit card; quite doable with an easily available adapter; and maybe even produces nicer images than Leica M lenses - providing that it is not used on a tripod with a Leica lens like this one, right?
    jonoslack's Avatar
    East Anglia & Cornwall (UK)
    11,728
    Help - really busy - big work think tomorrow morning - no time for explanations.
    R lenses are fantastic on the NEX7 - really fine - the handling is only odd for 5 minutes - after that you're holding the lens with your left hand (where you focus). Focus peaking makes focusing great. . . . . I haven't touched a tripod yet . . . I got a cheap Taiwanese adaptor which is also fine and focuses to infinity (novoflex were out of stock).
    The results are also fantastic - it's a grand combination producing fantastic results - next question?
    Just this guy you know
    Senior Member doug's Avatar
    693
    Michiel Schierbeek's Avatar
    Mar 2009
    Amsterdam/Normandy
    3,961
    762
    Did not use them on my NEX 7 yet, but I certainly will. They perform great on my Panasonic GH2 and Ricoh GXR, so why not on a NEX.
    The 50/2 and 90 Elmarit are not that big. Just a little heavy. Very stable.
    Even the APO Telyt 180/3.4, which is a little big and without tripod mount, is no problem.
    It is just that you don't want to drag a heavy lens like that around all day, because instictivly you want to support the lens to care for the mounts of those small bodys.
    I use a lot of cheap Pixco adapters, bought in Hong Kong from different vendors. They have them with or without tripod mount, which you can screw of in some cases.
    Michiel
    jonoslack's Avatar
    11,728
    I assume this is your setup Doug?
    Any camera body is tiny on the back of things like that.
    I find the 28-90 and 180 f2.8 apo to be perfectly acceptable. . . . . and the rewards are worth the effort.
    Godfrey's Avatar
    Jan 2009
    7,668
    "You call that a knife? Now this 'ere's a Knife." - Crocodile Dundee
    Shashin's Avatar
    May 2011
    Maine, USA
    4,188
    133
    Do you mount that on a tripod using the camera tripod socket?
    693
    No, not even with an R body. The lens has a tripod mount.
    Mar 2009
    Amsterdam/Normandy
    3,961
    762
    Perfect walk around lens with that handle.
    Michiel
    Hampshire, UK
    892
    20
    Hi Doug
    Superb! Of course if this lens was on the A77 you would also have the benefit of 3 stops of steadyshot (Sony say 4 stops but I don't believe it!). A beanbag is all that you need then! Your "riflestock" support would be perfect.
    Cheers, Dave
    www.simmondsphotography.com
    May 2009
    296
    Thanks very much for the encouraging input :-)
    Had looked all over the Sony forum for Jono's sample images so was happy for the tip to search the Leica section where I quickly found some here. I am not sure why but there is something in these images about the colors and tonality that reminds me of photos I had taken with my Leica years ago - maybe wishful thinking?
    Apart from the difference in MP do you expect the Nex-7 would give similar results to the Nex-5 or is there differences in the way the newer model is put together that produces different results?
    How about crop factor? Is it 1.6 ie 50mm R lens images the same field of view as an 80 mm lens on a 35 mm camera?
    Does the Nex-7 have manual focus confirmation with Leica R lenses + adapter?
    And one more question: any comments on experiences using the EVF?
    Jono hope your big work thing went well
    Apr 2008
    Hong Kong
    487
    I've been using Leica R lens with Sony A77 while waiting for the NEX-7. My R lenses are remount to Sony Alpha mount. So, I can make use of the in body stablization of Sony DSL body. The A77 has the same sensor and EVF of the NEX-7. Once you try the EVF and focus using Sony's focusing peak function, you don't want to go back to other DSLR with just a tiny dot to focus confirm.
    Crop factor is 1.5x.
    Here are few sample I took just the past weekend.
    1. Leica R 35mm Summicron
    C3 by yatlee, on Flickr
    2. Leica R 19mm
    B3 by yatlee, on Flickr
    3. Another R 19mm
    B2 by yatlee, on Flickr
    4. Leica R 35mm Summicron
    E4 by yatlee, on Flickr
    5. Leica R 35mm Summicron
    E2 by yatlee, on Flickr
    6. Leica R 100mm Elmarit
    D2 by yatlee, on Flickr
    7. Leica R 35mm Summicron
    E1 by yatlee, on Flickr[/QUOTE]
    nex100
    i wonder how do these big slr lens look with the nex7.
    May 2009
    296
    Thanks Yatlee for posting these very nice images. Seeing is believing. Good idea to get the lenses remounted though am not sure about the cost? Also curious why you would consider moving to Nex-7 if you already have A77. Is it for the smaller size or does the Nex-7 have other advantages?
  19. #19
    Apr 2008
    Hong Kong
    487
    Hi, The A77 belongs to my friend. NEX-7 should be here later this month. I can't wait.
  20. #20
    jonoslack's Avatar
    11,728
    Hi there Yat - great images . . . I'm very jealous of that 19mm!
    all the best
  21. #21
    Apr 2008
    Hong Kong
    487
    Hi Jono, My favorite lens is still the 50/1.4 ROM, but probably have to wait for the next Sony full frame to make good use of it. 19mm is great. I got it off a member here at a good price.
  22. #22
    jonoslack's Avatar
    11,728
    Quote Originally Posted by yatlee View Post
    I've got a few Leica M lenses, so the fixed focal length R lenses are generally of less interest. I bought 3 lenses at decent prices the minute I saw the focus peaking on the NEX7 - I'm still hoping that Leica do something, but if not I can always do a lens mount change!
