Step Down Rings for Sony NEX - Hood Alternate
Erik_A
Does anyone use Step Down Rings as a Sony NEX 16mm Hood Alternate? I want to do something like pentax did with the 40mm pancake lens hood (but for less than $65.00) so I bought a 49mm - 46mm as well as a 46mm-37mm step down ring. Do you think that this will work?
etrigan63
Worth a try but don't forget to factor in the cost of a new lens cap too. CV did something similar on their 40mm pancake SL II lens for Canon/Nikon/Pentax.
V
Vivek
Alphaman, That would be awesome (lightweight, functional and sleek)!:thumbs:
Is that available separately?
Erik_A
The NEX 30/3.5 macro "hood" (alc-sh113), seems to be a 1/4" plastic extension of the lens with a small rectangle cut-out, attaching to the bayonet mount in front becoming an integrated part of the lens. It isn't sold separately though (maybe directly through Sony).
I don't think that it provides enough hood protection for 16mm though since it is not long enough.
alphaman
I haven't seen it listed (yet) as a part or for sale but I think it's probably available from Sony direct. The part number is ALC-SH113.
As to Erik A's comment on protection, I'm not sure what he means; if it's to protect the lens from damage then no hood was designed to do that, however if he means in terms of function, I would expect that it is as good as any wide angle hood.
I haven't noticed any problems with using it and am glad I have one hood that suits both my 30/3.5 and my 16/2.8 and at the same time is small and discrete.
V
Vivek
Thanks, alphaman! I think I will ask someone to think about making a similar plastic hood.
Really fabulous!:thumbs:
alphaman
Alphaman - does it vignette the 16mm?
No, no vignetting even at f22.
I tried this combination out when I got my 30/3.5 and was pleasantly surprised that it worked.
Flare-wise - I have no alternatives to compare it to (some say that the 18-55 hood will work too), but generally while this hood isn't perfect, it works quite well.
V
Vivek
I checked the 30mm's hood on the 16mm, as alphaman pointed out, it does fit with a bit of tiny force. It isn't as smooth a fit as on the 30mm macro lens.
No vignetting problems at all.
Erik_A
Finally got my 49-46 and 46-37 step down rings and a 37mm cap from Hong Kong. See attached photos - I am very happy with the result - just as effective as the Pentax 40mm pancake hood in my OP (and just as awesome looking) What do you think?
