nex 7 and which lens in my wardrobe
danlindberg
I have:
1. Leica 35/2.8 Sumaron with goggles. Can I unscrew the goggles and use it on the nex?
2. Contax G. 45/2 Planar.
3. Contax/Yashica 45/2.8 Tessar T pancake & 50/1.7 Planar T.
With these lenses in the wardrobe, if you were to get only one adaptor for your new nex 7, what would be your choice and why?
fotoingo
I would use the Contax G 45mm f2 because it is near perfect.
Sharp from f2 on, no magenta corners nor corner smearing, has a short minimum focus distance and is relatively small.
Other wise you could invest in the smaller Minolta Rokkor M 40mm f2 for Leica M Mount but it is not as sharp as the 45mm wide open and has less contrast (this has good and bad sides but overall I like good contrast).
The Rokkor goes for about 300 € and a Leica M adapter can be found cheap on ebay.
Looks like this on a 5-n
Greets,
Ingo
1. not sure about the goggles - I think I saw the 135 with goggs on a nex.
2. stellar lens, wonky adapter.
3. inexpensive c/y adapters work fine.
DrCrane
No question, if you plunk down some cash to find a good adapter (I like the Kipon), I can not highly enough recommend the G45.
Small, light, fast and most of all SHARP as Hell...
