Page 24 of 28 FirstFirst ... 14 22 23 24 25 26 ... LastLast
Results 1,151 to 1,200 of 1388
Thread: Fun with the RX-1
  1. #1151
    Ithaca, NY
    3,384
    Re: Fun with the RX-1
    A few RX1R images processed from raw through AccuRaw Monochrome.
    Carl
    Gallery
  2. #1152
    Sep 2013
    544
  3. #1153
    Ithaca, NY
    3,384
    Couple RX1R monochromes from AccuRaw Monochrome shot today at marina.
    Carl
    Gallery
  4. #1154
    Apr 2008
    Netherlands
    12,915
    15
    Carl, the first one in the above post is just lovely!
    Me being a novice when it comes to PP (lack of effort I must say), may I ask what your general impression of the Accuraw output? Also how many pixels are getting out?
  5. #1155
    Ithaca, NY
    3,384
    Thank you Vivek. I'm also a novice when it comes to monochrome processing. I just used the default monochrome preset and adjusted the ETTR slider to lighten/darken images as necessary. No other processing, other than cropping, in either AccuRaw or LR. I like the AccuRaw monochrome output and in particular the smooth tonality. The output size of exported tiff files from AccuRaw monochrome is 6024x4024 pixels for the RX1R.
    Carl
    Gallery
  6. #1156
    Feb 2009
    Scottsdale, AZ
    443
    So I've been thinking: If the .75X (21mm) wide-angle converter for the 28mm/f2 FE lens can be modified to mount onto the RX1's lens and work well enough to be useful, then so should the matching .57X fisheye converter.
    That said, I'm not sure I have much reason to ever use a fisheye lens, although the effective 20mm focal length would certainly come in handy at times and it does offer a novel look.
    Hmm....
  7. #1157
    Sep 2013
    544
  8. #1158
    Apr 2008
    Netherlands
    12,915
    15
    Quote Originally Posted by scho View Post
    Thank you, Carl. I thought I read Sandy posting somewhere that you can read individual pixels. => 4x pixel output.
  9. #1159
    Feb 2009
    Scottsdale, AZ
    443
    How would "4x pixel output" even be possible? Demosaicing a file doesn't change the number of pixels it contains, it merely changes their RGB values by mathematically recreating the color components that weren't sampled at each sensel.
    FWIW, Raw Therapee, as well as several other RAW processing programs, also allows one to process RAW files without demosaicing them, which has caused me to start thinking about having my "broken" RX1 modified for monochrome-only use. While I'm not wild about losing the ability to control tonality post-exposure by tweaking the color channels for each image during the conversion to B&W, the potential increase in resolution has a strong appeal for me given the type of photography I like to do and since the camera isn't worth much in its present state, why not try it?
  10. #1160
    Apr 2008
    Netherlands
    12,915
    15
    Yes, I am confused about it. There was an example put out by Sandy (Accuraw creator) that showed 400% crop from a regular (bayer) camera vs 100% crop from a debayered one. Hence the query.
    I hope you find a solution for your RX1. You should keep in mind that the sensor could be completely destroyed during the monochrome conversion and be prepared to take that risk. Not for everyone.
  11. #1161
    Feb 2009
    Scottsdale, AZ
    443
    Ahh ... I'm an infrequent visitor here, so your reference was lost on me. <sigh>
    Yes, I'm aware of this risk, but given that Sony's repair facility has quoted a price of US$1,200 to repair this particular RX1 to proper working order, its present value is a few hundred dollars at best, which is marginally within my risk tolerance level. I was really only keeping it as a potential parts camera for my other RX1, but then I discovered I could zone-focus it using the macro ring and began using it for both street and tripod-based photography, where its (broken) autofocus capability wasn't needed (and despite focusing it via the macro ring, presumably a less than optimal way of doing so considering it has a floating element, it actually captures slightly sharper photos than my "good" RX1.) We shall see...
  12. #1162
    Ithaca, NY
    3,384
    AccuRaw Monochrome has special processing modes for cameras with IR modified sensors or sensors with CFA removed, but I haven't found anything other than a 400% preview mode that would allow changing image output resolution.
    Carl
    Gallery
  13. #1163
    Apr 2008
    Netherlands
    12,915
    15
    Quote Originally Posted by Audii-Dudii View Post
    Carl has answered the first part. Sorry for the confusion.
    That is a clever use of the broken RX1.
  14. #1164
    Sep 2013
    544
  15. #1165
    Sep 2013
    544
    More fun with the RX-1.
  16. #1166
    Sep 2013
    544
  17. #1167
    Vancouver, WA
    5,568
    549
    Jerome - very Miksang ...
  18. #1168
    Ithaca, NY
    3,384
    A few RX1R shots taken along the waterfront trail.
    Carl
    Gallery
  19. #1169
    Sep 2013
    544
  20. #1170
    Feb 2013
    886
    A couple while out wandering around.
    First is from the Red Cliffs National Conservation area.
    2nd from Confluence Park area.
  21. #1171
    Ithaca, NY
    3,384
    A shot with the RX1R in the foyer of Esperanza mansion on Keuka Lake near Branchport, NY.
    Carl
    Gallery
  22. #1172
    Feb 2013
    886
    A few shots from a place called Water Canyon.
  23. #1173
    Feb 2013
    886
    A little walk in the Pine Valley mountains.
    Shot handheld.
    Amazing camera. One of the finest I have ever had the pleasure to lay my hands on.
  24. #1174
    Jun 2008
    27
  25. #1175
    Feb 2013
    886
    Taylor Creek Zion NP on an overcast day.
  26. #1176
    Ithaca, NY
    3,384
    A few from a recent tour in the maritimes with the RX1R.
    Carl
    Gallery
  27. #1177
    Feb 2013
    886
    Great shots Scho. Thanks for sharing them.
  28. #1178
    Ithaca, NY
    3,384
    Two more from PEI.
    Cavendish Beach
    Green shutters on the "Ann of Green Gables" house near Cavendish.
    Carl
    Gallery
    Likes 7 Member(s) liked this post
  29. #1179
    Feb 2013
    886
    Couple more from Taylor Creek ZNP.
  30. #1180
    Jun 2008
    27
  31. #1181
    Feb 2013
    886
    A friend's cat.
  32. #1182
    Member Frits's Avatar
    Feb 2011
    Near Montreal, Canada
    177
    A quick snap of one of the granddaughters.
    R1Xr, indoors (available light only) @ f2.0
    Frits
    Likes 9 Member(s) liked this post
  33. #1183
    Ithaca, NY
    3,384
    A couple of snaps with the RX1R on a walk through an artsy neighborhood.
    Carl
    Gallery
  34. #1184
    May 2013
    St. Louis, MO
    105
    Just returned from a vacation with the Mrs. to Slovenia. The little RX1r did not disappoint. Did find that I've some dust on the sensor, will have to figure out if this is something under my warranty or not (as I bought used). Some of these are 2-4 shot stitched photos,
    Rastoke, Croatia
    DSC08899.jpg by jkjod, on Flickr
    Rastoke, Croatia
    DSC08895.jpg by jkjod, on Flickr
    Lake Bohinj, Slovenia
    DSC09734-Pano-2.jpg by jkjod, on Flickr
    DSC09695-Pano.jpg by jkjod, on Flickr
    DSC09683-Pano.jpg by jkjod, on Flickr
    Vintgar Gorge, Slovenia
    DSC09589.jpg by jkjod, on Flickr
    DSC09546.jpg by jkjod, on Flickr
    Lake Bled, Slovenia
    DSC09342.jpg by jkjod, on Flickr
    Lake Bled, Slovenia
    DSC09341.jpg by jkjod, on Flickr
    Lake Bled, Slovenia
    DSC09280-Pano.jpg by jkjod, on Flickr
    jkjod.wordpress.com
    flickr.com/photos/jkjod
  35. #1185
    Feb 2009
    Scottsdale, AZ
    443
    Here are some recent photos from my "85258" project, which involves me photographing my neighborhood within walking distance of my house late at night / early in the morning. All four photos were taken using a Sony SEL075UWC wide-angle converter modified to mount onto the RX1's lens bayonet:
    Some very minor cropping was done to the first and fourth photos during post-processing to tidy up the compositions. The wide-angle converter does add some additional distortion, but I am able to clean it up sufficiently for my purposes using the tools in RAW Therapee when I process the RX1's RAW files.
  36. #1186
    Feb 2009
    Scottsdale, AZ
    443
    And here are a few more taken with just the RX1 and no wide-angle converter:
  37. #1187
    Ithaca, NY
    3,384
    Another shot taken with the RX1R on the north coast of PEI near Cavendish Beach.
    Carl
    Gallery
  38. #1188
    Ithaca, NY
    3,384
    Two more RX1R shots from Hopewell Rocks provincial park in New Brunswick.
    Carl
    Gallery
  39. #1189
    Feb 2009
    Scottsdale, AZ
    443
    I returned home from last night's outing around 1:00 am and took this photo, among others, while I was out, as part of my project of photographing around my neighborhood at night:
    While I was out and about, however, I found myself thinking about the Sigma DP-1 Merrill, with its 28mm (effective) lens and smaller sensor, which would let me photograph with shorter exposures without giving up any depth of field, etc., and as I finished copying the files from my SD card to my primary and backup hard drives, I decided why not? and ordered a used one from Adorama.
    However, when I awoke later in the morning, I had an email from them saying my credit card had been declined due to an incorrect expiration date and/or security code. And sure enough, I had fat-fingered the security code while entering my info. But as I started to enter it again, only correctly this time, I had a change of heart and decided to cancel my order, because I really am quite happy overall with the performance of my pair of RX1s.
    G.A.S. is a sneaky lil bastard and it can -- and will! -- catch you out whenever you let your guard down and get sucked in by its sirens' song. It was a close call this time, but fortunately, I managed to stay the course... <phew!>
  40. #1190
    Jan 2013
    North of Copenhagen, Denmark
    117
    [QUOTE=jkjod;658967]Just returned from a vacation with the Mrs. to Slovenia. The little RX1r did not disappoint. Did find that I've some dust on the sensor, will have to figure out if this is something under my warranty or not (as I bought used). Some of these are 2-4 shot stitched photos,
    I got also dust on my sensor after only about 800 shots (RX1R), and send it to repair, but Sony answered, that they would not clean it.
    Very sorry, even the camera is very good: Will never buy Sony again, and Lloyd Chambers has also written about the VERY poor customer help from Sony.
    It destroys the fun with the camera, that you have to remove dust at every picture, and as everybody know, You can not clean it yourself from the camera, as You can
    with a DSLR
    Never Sony again.
  41. #1191
    Senior Member Hulyss Bowman's Avatar
    Jan 2013
    1,083
    I hope to have my hands on a RX1r new before the end of the year. After lot of study I do not think I need an another DSLR than my D700 and I do not think I should invest into more lenses.
    The thing is 37MP is too much for me, even more today than few years ago, when 37MP was introduced. So I need a very good 24MP camera and miss 35mm focal. Very good 24 MP camera like D700 do not exist. Some might say D750 but no, thank you.
    The RX1r is, as the date of today, the most finished camera Sony ever crafted. It is, built wise, superior to any A7 camera to date even A7r2d2.
    I've got dust on sensor with PS camera before, like the DP series. Every time, after a while, the dust go off. This is my experience and it is related to lens breathing. My advice is to put immediately a filter. My dust spot appeared only after filter removal for whatever reason.
    Kind regards - Hulyss - hulyssbowman.com
  42. #1192
    Jan 2013
    117
    Quote Originally Posted by Hulyss Bowman View Post
    Thanks, interesting, what filter do you recommend = Normally a filter degrade the sharpness ? (I do not care, what it cost, just want the very best)
  43. #1193
    Jan 2013
    1,083
    Quote Originally Posted by Kyndel View Post
    That's maybe true on some cameras ?? I did the "sharpnessloss" test on my DP3 Merrill with a Heliopan simple protective filter (or maybe it was UV) : No loss at pixel level. So I think you can just go with a good quality filter. If you want the best and your in the US go Breakthrough Photography filters.
    I would push even further, if you have access to Breakthrough Photography filters, I would even take a ND4 or(and) ND6 in + of protective filter since the camera is 1/2000s.
  44. #1194
    Feb 2013
    886
    I absolutely love my Rx1R. It makes me think of what a DP Merrill could have been properly engineered and refined.
    - - - Updated - - -
    Either a Heliopan or B and W.
  45. #1195
    Jan 2013
    117
    Thanks to Hulyss and Ute.
    No...... in Denmark (Europe), but I will certainly find it.
    By the way: I send the DP2M back because of the same (I have all 3 Merrills), and the new DP2M does not have the problem (at least untill now but perhaps I could have solved it in this way.
  46. #1196
    Jan 2013
    117
    Supplement: I was too fast, when I just wrote "sharpness", I more often see flare/ghosting when sun or some light is in the frame, and You use filter, but I will try Heliopan or B & W?
  47. #1197
    Feb 2009
    Scottsdale, AZ
    443
    I find this interesting. I guess I've been lucky -- knock wood! -- because I live in central Arizona, where we have dust storms regularly during the monsoon season, so there is lots and lots of dust in the air (which is hardly a surprise, what with this area being a desert and all), yet I can't recall the last time I had a problem with dust infiltrating any of my cameras or lenses.
    Of course, I've only been using my RX1s for approx. six months now, so who knows?
  48. #1198
    Senior Member Lucille's Avatar
    Jan 2015
    New Mexico
    396
    Albuquerque NM.
    Sony Rx1, 35mm Zeiss f/2
    the HepKitty
    Likes 10 Member(s) liked this post
  49. #1199
    Ithaca, NY
    3,384
    RX1R, manual mode, f/11, 1/250, auto ISO (500), 10 shots in fast continuous mode. Generated a 97 MP composite image in PhotoAcute3 and then re-sampled to 40 MP.
    Carl
    Gallery
  50. #1200
    Sep 2010
    269
    29
