Rhinocam appears to work with A7
Georg Baumann
At a glance, in horizontal mode it seems to work, not so in vertical for now, which could be a doodle to change.
photo 2 | Flickr - Photo Sharing!
The possibility to use MF lenses on the A7R is very intruiguing to me. If Fotodiox is willing to make a few changes this could turn into a 6x7.
Hell, they just have to make this work!
V
Vivek
This basically questions the claims of the medium format digital manufacturers that a nano precision is required for all the mechanical bits involved. Also, this IS the real tech cam, being able to see everything in live view. Some big changes are ahead.
I consider this as the biggest advantage of the E mount cams and not the use of Leica lenses which may/ (or most often) may not work.
Georg Baumann
Hi Vivek,
the moment I heard about this, thanks to Dierk's report, it was my very first reaction, that this sensor with MF such as the pristine Distagon 4/40 is my personal dream come true.
From an engineering perspective, the changes required to make the A7R work fully on the RC appear to be a no brainer, however, I have an email from Bryan, November 12th, saying that as of now, they had no plans for the A7R, but I imagine this could change, I certainly would hope so.
Ron Pfister
It seems like all that would be needed are different registration stops and a bit more space between the ground glass housing and the camera mount, right?
Georg Baumann
Bryan / Fotodiox does not have an A7 available yet, but he keeps me in the loop. I am reasonably hopeful they will make this happen. :D
Oh this would be wonderful and a reason for me to get the Cam and the A7r.
Please keep us up to date if it's going to work out!:)
Uaiomex
Time lapses are the problem with stitched landscape photos. I imagine the A7r should be better because it uses less movements to fill the 645 frame. Less lapses means less movements in the clouds for an example.
I they don't make one for the A7r, someone else will.
Eduardo
Hi Vivek,
