I tested mine on an Arca Cube/Gitzo 3 series with Novoflex and ASTAT at shutter speeds of 1/40th, 1/80th, 1/160th and 1/320th and a Zeiss 100mm Makr Planar at F5.6 which is an exceptionally sharp rig. There was a tiny blur at 1/160th that was insignificant at 50% view so I assume it was a 1 pixel movement. All frames looked very sharp. I used a 2 second remote delay so the camera wasn't touched at all.
All rigs have a sympathetic frequency other than those with electronic first curtain or LS lenses and a lot of LS shutter lenses also have curtain shutters behind them. I vaguely remember finding my D800E has another shutter speed it doesn't like with the same lens and setup, but I can't find the results.
I think this is absolutely what one would expect. However, I do get a rather higher percentage of sharp shots at 2x focal length shatter speed handheld than I do on the D800E.
Swings and roundabouts. As far as I am concerned, the A7R is just fine...
Yes, very clear, I'm afraid. Thanks! I will experiment with choosing long shutter speeds to avoid these issues, using ND-filters, if needed.
Good point, Tim. My little tabletop setup is not as subject to vibration as Victor reports with his tripod. By 1/60, I see very little blur which is certainly not what he finds. I'll try it on the Foba studio stand (El Gordo) to see what happens.
At any rate, different supports seem to yield different amounts of vibration, even with the same lens (Victor and I). Very interesting his comment re the Alpa FPS, by the way. First time I have heard Alpa, vibration, and "sent it back" in the same report.
At any rate, it appears that we have a support resonance going on, as opposed to internal vibration in the camera. That is good news as it is addressable.
Any chance you could make a couple of your nice sample shots with and without the ASTAT?
Tim,
I would think that the goal for this camera would be to use it as a light travel or field use camera. That would include lighter tripods and heads. Certainly the cube and series 3 tripod should be overkill and you shouldn't see any vibration ever!! If I gotta use a series 3 then I may as well use my 800e which is immune to all of this stuff. Or better yet my Alpa with a 150mm lens on a Gitzo series 1 traveler and an Acra head.... geez that head/tripod setup weighs 3.1 lbs. and allows me to use any shutter speed I want with no vibration - ever.I can also shoot my 800e with the traveler and Acra with vibration-less results and a cleaner file. Small and light should include the tripod and head....
Glad it all works for you......
Victor
I learned on a trip to Iceland with a Phase DF that there is no such thing as overkill for tripod! I agree that it would be lovely to have something that worked better on lighter rigs, but I have a 50:50 suspicion that when I try my little travel tripod it will yield similar results - some sympathetic frequency shutter speeds that are no-go and some that are fine. In any event, IMHO if you have to carry a heavy tripod rig, all the better reason to have a lighter camera!![]()
Well, the DF should be welded to an I-beam to calm that shutter down.I won't shoot mine - sits on a shelf with maybe 20 images taken. I really don't want to carry around a series 3 - I'm used to the little traveler which works with everything else. But....... maybe that's the only mitigating solution for now.
I also have experimented with my series 3 Gitzo with hits and misses with the A7r. More work to be done.....
Victor
I now believe this is a major problem. Here are images made on a sturdy little Novoflex tabletop tripod, with lightweight Manfrotto 494 ball head, AS clamp, and AS plate on the camera. All tight.
Apo Summicron M 90 asph at f3.5. A7r at iso 100. Distance about 5m. 10 sec delay on shutter.
100% crop 1 at 1/60, crop 2 at 1/2. No treatment other than white balance. Note the double exposure effect.
So, maybe all the bits are vibrating. Crop 3 taken with camera bolted directly to the bare tripod head. Again, 1/60. Worse.
Made similar tests on a massive Foba stand. Things are better. There is some blur, but the sort you expect from a whangy shutter. None of this double exposure effect.
My own feeling; the A7r has two types of shutter vibration. There is a gross movement which yields distinct exposures within one shot, and a more standard vibrational movement which yields blur. The factors which affect these two types of vibration are poorly understood by me, but they are related to the camera support structures. I do not know why I see them so clearly (as does Victor) and others do not appear to. Perhaps some cameras are defective.
Beyond suggesting that we all carry studio stands in our packs, I am at a loss.
Absurd results indeed, I bet I can do better at 1/60th just holding the bloody thing in my hands.
All the best.
