Results 1 to 2 of 2
Thread: A7r vs RX1 Build Quality ??
    Jan 2012
    I guess maybe a few people here have both the A7/A7r and the RX1. Do you think the build quality is the same? There has been so much praise about the RX1 being "a little gem" I wonder if folks feel the same about the A&/A&r ?
    Senior Member Joe Colson's Avatar
    Oct 2010
    North Carolina, USA
    Re: A7r vs RX1 Build Quality ??
    I have both. It's a struggle for me to describe the difference I see and feel. The RX1 "feels" more solid and metallic than the A7R. The fixed 35mm f/2 lens on the RX1 has the weight and density of a normal Zeiss lens while the native 35mm f/2.8 lens for the A7R is plastic and less dense. The battery door of the A7R is flimsy and has a poor latch mechanism, compared to the RX1. Countering that, the A7R SD card slot can be accessed without removing the camera from the tripod. The irony is that in a shooting day, using 64GB cards, I'm more likely to have to change the battery than change the SD card. The overall fit and finish of both cameras is very good, and no bits have fallen off either camera (yet).
    Of course, the RX1 has fewer buttons and dials, and its buttons and dials are easy to access. The A7R has some buttons that are made for tiny fingers, but that doesn't address your question about build quality.
    BTW, I'll likely sell my RX1, now that I'm satisfied with the A7R.
    Joe Colson Photography
