I'm pushing the sharpness in Standard style, but did not like the contrast push there when I tested it, seemed to lose shadow detail and while that not matter with focus that was somewhat distracting. Need to revisit/test these for B&W, thanks.Re your point number 2, if you also up the contrast and sharpness to max in the B&W setting it really helps for peaking and when you are in magnification. It also gives you a very good likeness of Tri-X in the viewfinder .
Thank you, that was very valuable.A couple of tips that are not really available in any 1. One can put the A7(R) or pretty much any E Mount camera into "always focus wide open despite chosen aperture" mode by setting the Live View Setting Effect off. Works both AF and MF and makes AF a bit better/accurate (the biggest reason my 24-70/4 OSS went back was AF accuracy in low light/short distance, F/4 just did not seem to be enough for pixel level accuracy with the A7R when viewed 100%) and less prone to hunt with for example FE 55/1.8.
This also makes EVF less noisy for MF since the sensor is getting more light and thinner DoF makes it easier to place perfect focus while focus zooming. Obviously not applicable if one is trying to balance objects in different distances inside DoF, but if one want to be sure one specific thing in "36 megapixel perfect" focus this is a good tool. The seems not to be any focus shift at least with the FE35/55, it is in my TODO list to test this with the Focustune software.
When Live View Setting effect is "on" the E Mount cameras will open up some to focus in low light based on metering but this is quite inconsistent, I tried to find some patterns in this behavior but did not find any.
Amen!3. Relative to the disabling ISO wheel, the default UI of A7(R) has very very badly placed WB adjustment, the rear wheel "right" press. Press this accidentally a couple of times in a row and you have crooked whatever WB preset up you have selected. By pressing the same button repeatebly one ends up in tint adjustment for WB and sets it to extreme blue if I remember correctly. I think I've saved 3 or 4 A7(R) from going back to Sony with "WB color tint issues" with this tip. Obviously will not ruin RAW photos but makes EVF look really strange and makes hair drop off from a jpg shooter. Horrid UI decision from Sony here.
FE55 focuses quite nice in low light and if you are not stopping down hugely it does open up to focus, if you shoot say F/4 it often opens to F/2.2 or so with live view on. The biggest benefit of turning Live view off is with MF and slow paced shooting. I've been using a Gossen Light meter a lot lately (TTL delay in A7R is a pain so manual flash only) and with proper calibration to sensors RAW output the exposure, at least from technical point of view, is purrfect every time. With light meter the the Live View is not of much use. A few reviews have said the A7(R) metering has tendency to underexpose a bit and when using light meter to meter the camera meter often thinks I'm at least a 3rd of stop overexposed.And to say that in low light (50% of mine is at ISO 6400) the FE55 still gets focus right almost all the time, even with LV On. Pretty amazing, but it is this way with the RX1 too. If I see much noise I check the histo, it is almost always U/E. Sadly for me maybe, LV is too valuable not to have On. And I agree re focus shift on this lens - I see none.
