a6000 compatibility issue with HVL-F60m flash
SamSS
Hi gents,
I have a problem with HVL-F60m flash issue with the a6000 camera.
It does not work correctly and it seems incompatible.
While the flash is on, it looks fine with well exposed but every shot turned out to be under exposed. Doesn't seem to match up or out of sync.
I've tried manual mode, TTL mode on the flash.
Fill flash, 1/60 on the camera.
Reset both camera and flash unit didn't help either.
If you have the same combo, please try and let me know your result.
Much appreciated.
Sam
BTW, the flash works perfectly fine on my a7 camera.
