douglasf13
Jono, this trick shouldn't work over ISO 400, as that is supposedly where the ADCs start behaving badly. If anything, try lower than 400, not higher. As I understand it, with some converters, the max ISO to try is 400, an with others its 200. Thanks for the work
p.s. thanks for the NR tip, Guy. Also, for those wondering, it's still good to try and get your histogram to the right with this technique, just like other high ISO shots.
