Check out this job I shot recently for a brochure. It's all on the A7rII with Canon glass. Most of the tight shots were with the 70-200mm f/2.8L IS II USM. Autofocus via the Metabones was awesome. I also used the 17-40 and the 17 TS-e quite a bit. Ok, actually, some of that was on the XT1... I almost forgot!Thanks again Chris. The additional info is very useful.
FWIW, I am thinking of switching to the A7RII because of its smaller size. The limited selection of Sony FE lenses is a concern so it is good to hear that adapted lenses work well.
Mainly three things (and some more) :I am particularly interested in why you guys did not go for a Canon body and took the Sony/Metabones route. Is it because of Canon’s limited dynamic range? As I want to learn from your experience could you please respond of this?
It’s much appreciated!
Thanks for the suggestion. I really need a wide, 24 or 17mm.If you don't already have the Canon T/S lenses, don't forget that there's also the option of Mirex's tilt-shift adapter. I'm using one, paired with an LA-EA3, to mount Mamiya 645 lenses with both tilt and shift. I've used Mamiya's 35mm, 45mm, 55mm, and 80mm.
