Page 8 of 11 FirstFirst ... 6 7 8 9 10 ... LastLast
Results 351 to 400 of 516
Thread: Fun with the RX-1R II
  1. #351
    Senior Member JoelM's Avatar
    Jun 2011
    San Diego, CA USA
    260
    Re: Fun with the RX-1R II
    Quote Originally Posted by thompsonkirk View Post
    One of many lovely blonde staircases at the renovated, enlarged, and just reopened SF Museum of Modern Art.
    They now offer the largest area for exhibiting photography in the United States.
    Kirk
    Attachment 118367
    Don't know if you planned it, but the wheelchair adds an additional dimension to the photo.
    Joel
  2. #352
    Sep 2009
    51
    Quote Originally Posted by The Ute View Post
    Just testing my new RX1R II.
    1st shot.
    It's serial # falls within the recall notice so I will likely be sending it in to be checked for light leaks.
    I wonder if they will replace it, repair it, or just send it back as checked
    OK ?
    Anyone sent one in recently ?
    You can test it yourself with a bright flashlight. Set a reasonably high ISO, keep the lens cap on, deploy the viewfinder and put the light next to the base of the viewfinder.
    My guess is you will see light leakage in this test. In any case, if you are in the serial range and you call them, you will be advised to send the camera for replacement. That was my experience and the experience of others. I can't think of a reason not to get the replacement.
    Matt
  3. #353
    Feb 2013
    853
    Quote Originally Posted by Matthew Runkel View Post
    Matt
    Thank you Matt. Appreciate the response.
    I sent it in. I'll see what happens.
    I hope their policy is just to replace any of them in the serial # range.
    If not I hope they do a thorough job of testing and/or repair.
    How long did it take you to receive your replacement ?
  4. #354
    Sep 2013
    New York
    463
    They should replace it with an absolutely brand new unit including the box and accessories. Mine took just 5-6 business days to be at my door from the day I sent it. I live in New York, so your experience may be different.
    Too much to list, let's just say I have a bad case of GAS.........
  5. #355
    Feb 2013
    853
    Quote Originally Posted by Pradeep View Post
    Thank you for your response.
    Just curious.
    Were you able to verify that you had a light leak before you sent it in ?
  6. #356
    Apr 2008
    Netherlands
    12,795
    15
    Nothing special. Just on my way to visit the cardiologist for a check up in Leiden (a nearby university town).
    Untitled by Vivek Iyer, on Flickr
    RX1R II, Leiden
  7. #357
    Sep 2013
    New York
    463
    Just curious.
    I should have, but did not. Mine was in the range that was supposedly affected. Ideally I should have tested it myself, but was not sure if it did not have the leak with my tests, it would mean that it was perfect or whether I did not test it enough. It is an expensive piece and I did not want to be caught later when it would be too late to exchange it.
  8. #358
    Feb 2013
    853
    Once again I thank you for your response.
  9. #359
    k-hawinkler's Avatar
    Dec 2009
    The "Land of Enchantment"
    2,629
    RX1R II, Leiden
    Thanks Vivek. Lovely subject and image. Good luck with your check up.
    With best regards, K-H.
  10. #360
    Apr 2008
    Netherlands
    12,795
    15
    Thanks, K-H.
    Interestingly, the heart muscles can regenerate after damage in many cases and luckily that appears to be happening in mine.
  11. #361
    Dec 2009
    2,629
    Thanks, K-H.
  12. #362
    Apr 2008
    Netherlands
    12,795
    15
    Backyard fun.
    RX1R II, The Hague.
  13. #363
    118
    Vivek,
    Quite a change in your street photography!
    Paul
  14. #364
    Sep 2009
    51
    Just curious.
    It took just about two weeks from sending my old one to receiving the replacement.
    Blasting a powerful LED flashlight at the seam left no doubt that mine was affected. Never noticed in actual use, of course.
  15. #365
    Apr 2008
    Netherlands
    12,795
    15
    Quote Originally Posted by camping View Post
    Vivek,
    Paul
    Thanks, Paul.
    Snapped in the same way, unorchestrated.
  16. #366
    Feb 2013
    853
    I used a small LED light to check mine and found no issue but decided to send it in anyway because I wanted to be sure.
    I wonder if they will still replace it or just send mine back ?
    From what I understood the policy was simply to replace them.
    I guess if they check mine and find no leaks they might just send it back to me.
  17. #367
    Apr 2008
    Netherlands
    12,795
    15
    Earlier today.
    RX1R II, The Hague
    Likes 7 Member(s) liked this post
  18. #368
    2,546
    Earlier today.
    RX1R II, The Hague
    Vivek,
    If that does not evoke angina then you are doing well ...
    Warm regards,
    Bob
  19. #369
    2,546
    Thanks, K-H.
    Vivek,
    Regeneration is probably not the case ... we talk about hibernating ventricles ... which recover over time as oxygenation improves ... whether collateral flow
    or initial edema resolves with improved graft flow.
    I am pleased that you have had a marked improvement!
    Avoid tobacco products at all costs ... exercise ... keep your blood sugar levels and cholesterol within strict low levels ... and pray for a long blessed life.
    Enjoy the days you have ...
    Best regards,
    Bob
  20. #370
    Apr 2008
    Netherlands
    12,795
    15
    Thanks, Bob!
    No tobacco prods. and even stricter diet on top of what had.
    RX1R II, The Hague
  21. #371
    Nov 2012
    113
    Quote Originally Posted by docmoore View Post
    Vivek,
    ... exercise ...
    Walk a lot - your camera is your best exercise plan 👍
  22. #372
    Apr 2008
    Netherlands
    12,795
    15
    RX1R II, The Hague
  23. #373
    Apr 2008
    Netherlands
    12,795
    15
    Owls were in the neighborhood.
    RX1R II, The Hague
  24. #374
    Feb 2013
    853
    A rose from our backyard.
  25. #375
    Apr 2008
    Netherlands
    12,795
    15
    Concrete blocks with brick facade.
    RX1R II, The Hague
  26. #376
    2,546
    Vivek ....
    12000 + posts?!
    You own this place.
    Bob
  27. #377
    Apr 2008
    Netherlands
    12,795
    15
    I am just a visitor.
    RX1R II, The Hague
  28. #378
    Apr 2008
    Netherlands
    12,795
    15
    RX1R II, The Hague
  29. #379
    Apr 2008
    Netherlands
    12,795
    15
    RX1R II, The Hague
  30. #380
    Apr 2008
    Netherlands
    12,795
    15
  31. #381
    Feb 2013
    853
    Spring Creek Canyon
  32. #382
    Feb 2013
    853
    One more from Spring Creek.
  33. #383
    No CA
    699
    Very nice! Could you darken the skies a bit?
    Kirk
  34. #384
    Feb 2013
    853
    Kirk
    Yes. I overdid it trying to open up some shadows.
    Thanks for the comment.
    I reposted the original w slighter darker skies above.
  35. #385
    Feb 2013
    853
    Grand Canyon North Rim
  36. #386
    Feb 2013
    853
    Mt. Hayden
  37. #387
    Feb 2013
    853
    Sunflower w backlighting.
  38. #388
    Apr 2008
    Netherlands
    12,795
    15
  39. #389
    23,566
    2555
    Okay time to fess up. Just received a used one today and really looking forward to using it. My purchase included a lot of extra stuff that turns out I don't need all of it . Check out the B&S as there is some great stuff for sale. My only little issue is the eye cup and keeping the rubber on. Gorilla glue might be the answer as I want to keep the EVF up.
    Looking forward to joining the party.
    www.guymancusophotography.com
  40. #390
    Apr 2008
    Netherlands
    12,795
    15
    Congrats, Guy! Welcome to the party!
  41. #391
    23,566
    2555
    Thanks this should be fun. Now to find a cool spot on earth. Its already in the 115 degree zone
  42. #392
    New Member icaro's Avatar
    Apr 2016
    Verona (Italy)
    7
    Click image for larger version.
    Jpeg on camera (Brecht on stage).
    Likes 9 Member(s) liked this post
  43. #393
    Apr 2016
    Verona (Italy)
    7
    Jpeg on camera.
  44. #394
    Apr 2016
    Verona (Italy)
    7
    Cuba, April 2016
  45. #395
    Feb 2013
    853
    Forsyth Canyon at Pine Valley, Utah
  46. #396
    Senior Member DougDolde's Avatar
    Oct 2015
    Joshua Tree, CA
    292
    Thanks, Bob!
    Eliminate all grains from your eating !
    I've been off grain for a year and a half.
    See Dr. William Davis | Cardiologist & Author of Wheat Belly Books
  47. #397
    Vancouver, WA
    5,490
    543
    Palouse ...
    Attached Images Attached Images
  48. #398
    Feb 2013
    853
    Palouse ...
    I'd love to see it in the Fall.
  49. #399
    Apr 2008
    Netherlands
    12,795
    15
    RX1R II, The Hague
  50. #400
    Apr 2008
    Netherlands
    12,795
    15
    A short while ago, stone throw away from my place, in the Hague.
    "The Boss" gave a concert. A bunch of us from the neighborhood could hear it for free (though could not see).
