Results 1 to 4 of 4
Thread: C1 9.1 Update lots of Sony
    Here is the lot of info
    Capture One 9.1 Features
    Under the hood Library refactor (Mac)
    Canon PTP tethering engine
    Re-factored Next Capture Adjustments for Orientation
    Re-factored Next Capture Adjustments to allow Metadata in adjustments
    Improved handling of Tiff assets that include Alpha channels or Layers (view only)
    Various improvements to Keyboard shortcut menu
    New Features:
    New: Rotatable live view (as part of Orientation refactor)
    New: Color Editor tools: Saturation, Hue and Lightness uniformity for Color Editor
    New: Export/Output Keyword List restrictions
    New: Shortcuts for Reset Counters
    New: Shortcuts for fill/invert mask and change/cycle layers
    New: Shortcuts for “Select by…”
    New: Shortcuts for “Create album by…”
    New: Shortcuts for “Select by same…”
    XF compatible features:
    Sequence workflow tools:
    Create albums from Sequence ID
    Filters for sequence types, counts, ID
    Name Tokens for sequence types, counts, ID
    Dynamic locations for sequence types, counts, ID
    Camera Support:
    Olympus Pen-F
    Olympus Om-D E-M10 Mk II
    Sony A68
    Sony a6300
    Sony RX1R Mk II (revised implementation)
    Ricoh GR II
    Pentax K-S2
    Panasonic G7
    Leica SL
    Lens Support:
    Nikon 24-70E VR
    Nikon AF-S DX NIKKOR 18-135mm f/3.5-5.6G IF-ED
    Sigma 150-600mm F5-6.3 DG OS HSM (Nikon mount)
    Sigma 120-300mm F2.8 DG OS HSM | S (Canon mount)
    Carl Zeiss Sonnar T* FE 35 mm F2.8 ZA
    Carl Zeiss Sonnar T* E 24 mm F1.8 ZA
    Panasonic LUMIX G VARIO 14-42mm F3.5-5.6 ASPH. MEGA O.I.S.
    Sony E PZ 16-50 mm F3.5-5.6 OSS (SEL1650) (improved profile)
    Sony FE 24-70 2.8 GM (SEL2470GM)
    Sony FE 85 1.4 GM
    Bug Fixes:
    (Mac) Functionality Bugs
    Browsing images in the importer window causes setting files to be saved on disk
    Keywords are added when browsing folders or canceling an import operation
    Import and Pack as EIP: imported images show a “1” at the end of their filenames
    Library: various bugs (performance, crashes, Smart Album handling)
    Camera tool: ISO string badly clipped if too long
    Brush size slider does not respond correctly to mouse scrolls
    Live View: pixelated images appear on some occasions
    Color Editor and Curve tool: undo not always working as expected
    Curve tool: cannot edit curves when loupe tool is selected
    Curve tool: pickers do not always get selected when clicked
    Color Editor: color patches are missing in Express (for Sony)
    Keystone: copy/apply buttons always disabled
    UI cosmetics (especially Keywords and Keyword Library tools)
    Fixed a bug in handling styles for Next Capture Adjustments
    Fixed an orientation bug for Next Capture Adjustments
    Library tool performance and minor fixes
    Fixed crash using IQ3 100MP and FireWire
    Keyword Library handling minor fixes
    Fixed moire persistency for layers
    Fixed an issue for naming duplicate files while batch renaming
    Library tool: improve overall UI performance
    Library tool: a number of cosmetic bugs (display of icons, expand/collapse)
    Next Capture Adjustments: fix handling of Rating and Color Tag
    Next Capture Adjustments: fix handling of Crop when Orientation is set to non-default values
    Filters tool: properly add new filters to a group
    Fix reset of lens distortion when resetting a Variant
    Color Editor: fixed undo/redo
    Mask drawing: fixed a flickering issue appearing when drawing masks after an undo operation
    ICC profile menu: fix a bug causing some custom profiles not to be shown in the menu
    (Win) Functionality Bugs
    Various crashes and hangs
    Search only allowed a single search string
    Session can not be opened over UNC path
    Importing a catalog does not include all images
    IPTC getting garbled when using Chinese characters
    Main window hangs when trying to recursively import many folders
    “Sort selected by Color Tag” does not work.
    Active Filters in the Filters tool would remain active even if hidden
    Film Grain type drop down disabled when Capture One starts
    Pink color Tag improperly mapped to Photoshop urgency
    When replacing a style, Capture One deletes the style without saving a new file with the changes.
    Sorting of Keywords in the Keyword Library tool is case sensitive
    Cannot delete some Keywords from session in Keyword Library
    Error Exporting Keyword Library to paths containing exotic characters
    Camera tool: pending count slow/not updating when shooting continuously
    Selection points on image will move when panning the image
    Linked Zoom using Zoom slider in Multi-view mode not working
    When creating a Mask from the Color Editor it does not get a selection point
    Local Adjustments: Passing over a hidden selection point changes the cursor
    Temporary file is not deleted when importing a catalog inside another catalog
    Cannot stack built-in Curve presets
    Difficult to Crop from bottom of image
    Variant collapsed state affects initial filters counts
    Camera tool: +/- ISO tab changes size
    All Images not updating after image is processed
    Import of a Session into a Catalog doesn’t create a collection under “Recent Imports”
    Next Capture Adjustments – only one Style can be added
    Fixed bug where it was sometimes not possible to remove a Keyword from a Session Keyword Library
    ICC-Profile: naming changes when setting it to default for camera
    Dragging a Session favorite to Albums does not create an Album
    Color Editor: Reset selected tab removes all presets regardless of tab
    Improved global modification of Keywords
    Crop tool does not respond correctly if Next Capture Adjustments is set away from default
    Vignette tool does not reset when Amount title is click-hold
    ‘Select by Sequence ID’ works as ‘Select All’ if no ID
    Vignetting tool is disabled by default
    Variants not persisted when making Keyword Library changes in another Collection
    Crash Bugs
    Fixed a crash when removing a filter
    Fixed a crash in the Curves tool when dragging and entering keyboard shortcuts
    Fixed a crash when clicking in empty areas of the Keyboard Shortcut Editor
    Fixed a crash when creating/moving collections the Library tool.
    Fixed a crash when processing LCC filesa
    Known Issues:
    All users
    Browsing folders containing unsupported image files may affect application performance.
    Previews from earlier versions of Capture One may be updated. In some cases, this can affect the application performance the first time images are viewed in this version of Capture One.
    If using a non US laptop keyboard it might be preferable to change some of the standard keyboard shortcuts.
    Editing images in external applications other than Adobe Photoshop might result in unexpected behavior.
    Operation under virtualization software (e.g Parallels, Hackintosh etc) may cause instability. We do not recommend you use these OS configurations.
    Mac Users
    It is only possible to show the Capture One toolbar in “Icon Only” mode.
    Live View over USB can stall without the use of a repeater.
    Windows Users
    Windows drivers are required for some older models of Canon DSLR cameras to be able to shoot tethered. These drivers are available from Canon’s web site.
    If you have Bonjour 2.0.3 installed you may experience problems with Capture Pilot. Bonjour 2.0.2 (shipping with Capture One 9) and 2.0.4 (shipped with iTunes) have been tested to work with Capture Pilot. To check the version number of Bonjour, go to ‘Control Panel’ and select ‘Programs and Features’.
    Importing a catalog can result in the last picture not getting imported.
    Operation under RAMDisk by Dataram is known to cause issues with disk labeling. Capture One is not supported with this configuration.
    k-hawinkler's Avatar
    Dec 2009
    The "Land of Enchantment"
    Re: C1 9.1 Update lots of Sony
    Thanks Guy. Could you please post a URL for this info? TIA.
    With best regards, K-H.
    Feb 2009
    You can download the official release notes from here:
    Sorry out testing lenses
