has anyone used the new shoe mount transmitter and shoe-fitted remote wireless units from Pocket wizard? Seems to be a very direct system with no need for cables and adapters. they also have radio protocol for Canon and Nikon TTL. if only PW would make that work with the weird Sony/Minolta shoe
They are canon only at the moment and plagued with loads of problems. The lighting board on FM has about 3 questions a day with people saying that they either can't get them to work at all or they only work 15-30 feet. Added to that are reports that the hotshoes are not strong enough, there are photos around that show two TT1's with a snapped hotshoe from mid wedding. Not sure I want to see what happened to the flash attached to them! Some people are not having any problems but I'm not buying into a system that's a maybe. Waiting for the EU radiopopper units.
I did an international ad camaign two weeks ago using the ST-E2 outdoors and even with 6ft distances it was nowhere near reliable enough if the slave was off axis. I was using someone elses equipment (most of mine is 2500 miles away) otherwise I could have used one of my 3 580's as master.
Good luck with the sony's Marc. I hate the menu system on practically any peice of camera equipment, having to remember which settings to set, which order of button presses (I hated the canon 1 series cameras). The old canon 420ex had a perfect system for off camera. A switch to put it into slave mode and two permenant displays with buttons underneath to choose channel and slave group. Add the ratio display from the ST-E2 and add those to the 580 (which would then need a much smaller LCD only) and you would have something really useable! I've gone back to using a 580 mk1 on camera just for that master/slave switch (instead of menu) that I'd missed so much when shooting weddings.
