Page 10 of 12 FirstFirst ... 8 9 10 11 12 LastLast
Results 451 to 500 of 552
Thread: "Capturing Infrared"
  1. #451
    Los Altos, CA
    10,304
    1028
    Re: "Capturing Infrared"
    LOL, maybe it's just gonna take me a bit to get used to it. I thought the 630 would be my goto, but I may be happier with the 590. Need to experiment more
    home: www.getdpi.com
  2. #452
    iiiNelson's Avatar
    Sep 2008
    Texas/California/North Carolina
    2,888
    So here is my first capture with my "new" A7r Full Spectrum conversion... This was with the B+W 091 deep red which is supposed to be roughly 630nm. Set a custom WB, and it looked good in the VF, but colors seem overly vibrant -- thoughts? :
    Original as out of cam:
    R<>B Swap:
    But here is a B&W conversion from the captured file -- and I'm actually pretty impressed:
    I agreed that they're nice shots. It's possible that B+W filters leak a bit more visible light than the rating suggests but I'd expect there to be a good bit of vibrancy from a filter that lets in wavelengths down to 630nm. Going by LifePixel's website that's about halfway between the Super Color IR and the Enhanced IR filters
    - - - Updated - - -
    R<>B Swap:
    Priolite Ambassador | Sony Visible Light & IR Photographer
  3. #453
    Ithaca, NY
    3,384
    Shooting with no filter on the lens can also produce some nice FS files for B&W conversion.
    Carl
    Gallery
  4. #454
    Wisconsin
    3,535
    118
    Your colors seem more bold than I would get with my 665nm. You use Capture One, right?
    I do like the black and white one the best.
  5. #455
    Ithaca, NY
    3,384
    My A7R just came back from LifePixel with a full spectrum conversion. Still had all of my Kolari filters that I used previously on the A6000 FS so I ran through some calibration shots and tests.
    The following series was shot using the Sony FE 28/2.
    CC filter
    No Filter
    590nm filter
    850nm filter
    and here is one with an R72 (720nm) filter on the CV 15mm III at f/8. No hot spot evident.
    Carl
    Gallery
  6. #456
    Ithaca, NY
    3,384
    Two 4 shot panos using the A7R-FS on the Cambo Actus with SK 47/5.6 APO-Digitar XL.
    No Filter
    665nm Filter
    Carl
    Gallery
  7. #457
    Ithaca, NY
    3,384
    Still testing and calibrating. This time with wides on the A7R FS and no filter.
    First up the CV 15 III again. There was some pronounced cyan corner vignetting so I had to use a dng flat field correction. Also this lens is a bit softer overall and on the edges with the A7R compared to near perfection on the A7RII.
    Next the Samyang 24mm TS lens. My copy is with Nikon mount so I used a Novoflex NIK/E adapter. Works fairly well with the A7R FS and no cyan vignetting, but again not as good corner/edge performance compared to the A7RII.
    Carl
    Gallery
  8. #458
    Wisconsin
    3,535
    118
    Sony A7II Full Spectrum
    Sony 16-35 f/4 FE and 590nm + 10 stop ND
    Converted to black and white in PS
    [img]Bond Falls-1 by Cindy Flood, on Flickr[/img]
    -Cindy
    www.cindyflood.com
    www.flickr.com/cindyflood
    Likes 11 Member(s) liked this post
  9. #459
    Jan 2013
    Minnesota, USA
    921
    Quote Originally Posted by Cindy Flood View Post
    Bond Falls-1
    Really beautiful!
  10. #460
    Ithaca, NY
    3,384
    Looking south down the west branch of Keuka Lake from the patio at Esperanza Mansion. Handheld shots with the A7R-FS and Sony FE 28/2 lens.
    CC Filter
    590nm Filter, R/B channel flip and yellow/blue hue/sat adjustment
    Same as above converted with B&W Adjustment layer, darkening blue and lightening yellow.
    850nm Filter
    No Filter, hue/sat adjustment for blue and yellow
    Same as above, B&W adjustment layer, darken blues and lighten reds and yellows.
    I think of the three B&W options above I prefer the last one for the range of tones. Easy as well because you don't need any IR pass filters when shooting.
    Carl
    Gallery
    Likes 7 Member(s) liked this post
  11. #461
    Wisconsin
    3,535
    118
    Sony A7II full spectrum, 55 f/1.8, 720 nm
    Re-enactment of skirmish outside of Atlanta, 1864
    [img]Re-enact IR-2 by Cindy Flood, on Flickr[/img]
    -Cindy
    www.cindyflood.com
  12. #462
    Jun 2008
    541
    Just came back from a little trip to Florida. Took only this camera with the 20 and the 50. And my RX100-3 that stays with me all the time. Talk about traveling light!
    Super Color A6000 with 20mm pancake. Cape Coral, Fla.
  13. #463
    Tucson/Carmel/Jackson Hole
    4,263
    I blame Guy for starting this . A couple weeks ago he posted a thread of how he removed the petals off his Voigtlander CV15mm V III lens so that he could use his 67mm filters instead of the 58mm. Of course I found this interesting and thought it might be a fun project, however I was unwilling to spend in excess of $700 on a lens for a "fun project" so I put it out of my mind. (Yeah sure!)
    Browsing E-Bay this past week I happened upon a sale for a V II that also included a M-E adaptor for way less and of course I bought it. The difference seems to be the filter size changed from 52mm on the V II to 58mm on the V III (I also think the front element is larger on the III). Since I still have a couple 55mm IR filters I thought if a 52-67 step up ring caused too much problems I could always opt for the 55mm. Turns out the 52-67 works just fine.
    Here's a couple samples from yesterday shortly after cutting and trimming; all taken with a Voigtlander 15mm V II lens.
    f/5 1/400 ISO 250 830nm (handheld)
    f/5 1/400 ISO 125 830nm (handheld)
    f/8 1/60 ISO 100 830nm (handheld)
    f/8 1/320 ISO 100 Full Spectrum (handheld)
    Once you get over the fear of cutting everything else is okay.
    don
    Don Libby
    Iron Creek Photography
    Blog
    Tucson AZ
  14. #464
    Sep 2014
    20
    665nm IR fun in Maui
  15. #465
    Aug 2008
    Carmel/Tucson
    2,244
    Super swamped, but wanted to share an IR image taken at a recent engagement portrait session. I'll have a blog post up at some time (when I get a breather to write!) on using IR flash with different available filters in the IR spectrum. This particular image used a Profoto B2 with an IR flash adapter, 715nm filter, and a Sony A7r full spectrum camera, 24-70 with 720nm filter. Custom WB with Expodisc and converted to B&W. The IR Flash adapter works with the Profoto B1 and B2.
    Name:  _DSC2251 Matt Natalie IR Web.jpg
    Ken
  16. #466
    Wisconsin
    3,535
    118
    A7II, Voightlander 12mm, 590nm
    [imgPainted Lady by Cindy Flood, on Flickr
    [/img]
    -Cindy
    www.cindyflood.com
  17. #467
    Ithaca, NY
    3,384
    [img]Painted Lady by Cindy Flood, on Flickr[/img]
    Hi Cindy. Do you know if Voigtlander updated this lens, as they did with the 15 v III, to eliminate cyan/magenta vignetting?
    Carl
    Gallery
  18. #468
    Wisconsin
    3,535
    118
    Carl, Mine is the version II with rangefinder coupling. The new one is coming out for the Sony's in the spring.
    -Cindy
    www.cindyflood.com
  19. #469
    4,263
    Thanks Cindy, I'm in Sedona for a wedding then off to Bryce and have been using my 15mm thinking that I'd like to go slightly wider with the 12mm. Based on what I see I just might bite the bullet and get the 12 then try to sell the modified 15mm.
    Don Libby
    Blog
    Tucson AZ
  20. #470
    Wisconsin
    3,535
    118
    A7II FS and Voigtlander 12mm with 830nm filter
    Attached Thumbnails Attached Thumbnails Click image for larger version.
Name:	Havasu Morning-1.jpg
    -Cindy
    www.cindyflood.com
  21. #471
    Wisconsin
    3,535
    118
    Sony A7II FS and 772nm on 55 f/1,8
Name:	flying high-1.jpg
    -Cindy
    www.cindyflood.com
  22. #472
    Dec 2014
    180
    nikon 1 S1 IR 720nm
  23. #473
    Wisconsin
    3,535
    118
    Sony a7II Full Spectrum, Contax Carl Zeiss G 45 f/2 on Techart, 830nm filter
    Palms on the lakeshore
Name:	Palms on the lakeshore-1.jpg
    -Cindy
    www.cindyflood.com
  24. #474
    Senior Member viablex1's Avatar
    1,428
    Hey Cindy that dern near looks like film, nice!!
  25. #475
    Wisconsin
    3,535
    118
    Quote Originally Posted by viablex1 View Post
    Thank you!
  26. #476
    iiiNelson's Avatar
    Sep 2008
    2,888
    Couple of IR Panoramas I took (Color and B&W) a couple weeks ago.
    PalermoPano_IR by Tre Nelson, on Flickr
    PalermoPano_IR 1 by Tre Nelson, on Flickr
  27. #477
    iiiNelson's Avatar
    Sep 2008
    2,888
    Ken
    Any updates on the IR flash adapter?
  28. #478
    Dec 2014
    180
    nikon 1 S1 IR 720nm
  29. #479
    Wisconsin
    3,535
    118
    Some 590nm faux color
Name:	under the bridge.jpg
Name:	Clouds over the bridge.jpg
Name:	Bridge 590nm.jpg
    -Cindy
    www.cindyflood.com
  30. #480
    Wisconsin
    3,535
    118
    Canal in 665nm faux color
    -Cindy
    www.cindyflood.com
  31. #481
    Apr 2008
    Netherlands
    12,899
    15
    A couple of pics from my new IR cam.
    Untitled by Vivek Iyer, on Flickr
    Hacked Panasonic GM1, Olympus 17/2.8, RG690
    Hacked Panasonic GM1, Panasonic 20/1.7, RG690
  32. #482
    Apr 2008
    Netherlands
    12,899
    15
    Hacked GM1, Enna 20/2.8, RG600 filter, The Hague
  33. #483
    Senior Member f6cvalkyrie's Avatar
    Feb 2009
    Belgium
    1,606
    29
    IR shots (680nm) with my FS G1 of an approaching thunderstorm ...
    and a 5-shot panorama stitch ...
    CU,
    Rafael
    E-M1/GH2/G1 Full Spectrum & lots of lenses
    http://www.flickr.com/photos/f6cvalk...th/9226689839/
  34. #484
    Apr 2008
    Netherlands
    12,899
    15
    Awesome, Rafael!
  35. #485
    Apr 2008
    Netherlands
    12,899
    15
    Hacked GM1, Panasonic 20/1.7, RG720 filter, The Hague
  36. #486
    Feb 2009
    Belgium
    1,606
    29
    No thunderstorms today ...
    From the FS G1 with a 720nm filter
    CU,
    Rafael
  37. #487
    Aug 2008
    Carmel/Tucson
    2,244
    Quote Originally Posted by HiredArm View Post
    Sorry---I've been swamped (overwhelmed) caring for my mom during her transition in memory care here in Carmel. Getting old (with dementia) really sucks. Her---not me.
    I'm about half-way done writing the blog article on IR Flash with the Profoto B1 and B2 (portraiture and Landscapes), still need to flesh it out more. Picked up some tips shooting IR adapted flash while I was shooting with the Profoto B2 at Alcatraz at Night with CI in Carmel a few months back. The IR flash adapter is relatively easy to do, and I'll try my best to show how I modified the Profoto B1 and B2.
    Working on it!
    Ken
  38. #488
    iiiNelson's Avatar
    Sep 2008
    2,888
    Working on it!
    Ken
    No worries and I hope your mother's transition goes well. I've dealt with that sort of responsibility off and on with my grandmother who also suffers from dementia. Yes it does suck when they get frustrated that they can't remember things.
  39. #489
    Apr 2008
    Netherlands
    12,899
    15
    Foggy
    Hacked GM1, Olympus 17/2.8, The Hague
  40. #490
    Apr 2008
    Netherlands
    12,899
    15
    The Hague
  41. #491
    Wisconsin
    3,535
    118
    Sony A7II Full Spectrum, 590nm
ID:	118964   Click image for larger version.
    -Cindy
    www.cindyflood.com
  42. #492
    Apr 2008
    Netherlands
    12,899
    15
    Hacked Panasonic GM1, 35-100 f/4-5.6, Hoya 720nm
  43. #493
    Wisconsin
    3,535
    118
    Shrimp boat in the SC low country. Sony A7II Full Spectrum, Voigtlander 15mm III and 590nm Faux Color
Name:	shrimp boat 2-3.jpg
    -Cindy
    www.cindyflood.com
  44. #494
    Apr 2008
    Netherlands
    12,899
    15
    Two from Leiden, The Netherlands.
    Likes 9 Member(s) liked this post
  45. #495
    Feb 2009
    Belgium
    1,606
    29
    from a visit to a lady who owns a mysterious old orchard in Russia ...
    FS G1 with 680 external filter - very cloudy weather ..
    CU,
    Rafael
  46. #496
    Apr 2008
    Netherlands
    12,899
    15
    Both with a Hacked Panasonic GM1, Panasonic 12-32 zoom, RG690 filter, The Hague
  47. #497
    Wisconsin
    3,535
    118
    Vivek, Have you tried shooting any flowers with your ultraviolet filter? I've read that details can be revealed on flowers that we don't see.
  48. #498
    Apr 2008
    Netherlands
    12,899
    15
    Hi Cindy, i have been shooting in UV for over a decade now (make that decade and half), starting with film. Yeah sure. Most who shoot in UV are beating the dead horse of how some flowers look in UV. I even shoot street in UV because I can.
    All my UV gear is up for sale now for a small amount of cash, including an UV-Nikkor that i bought from a true digital pioneer Fumio Yokozawa.
    (UV photography is as old as photography itself, btw)
    Ihave loads of UV pics on my flickr space.
    Sale Items (http://www.getdpi.com/forum/gear-fs-...8806-sale.html)
  49. #499
    Apr 2008
    Netherlands
    12,899
    15
    Amsterdam (Panasonic GM1 with 35-100 f/4 RG720nm).
    traffic
  50. #500
    Aug 2008
    Carmel/Tucson
    2,244
    Sorry for the delay!
    I've finally finished my blog article on using IR Flash with IR photography! It is relatively easy to make an adapter---to convert the Profoto B1 or B2 to infra-red, in a variety of wavelengths.
    See the blog on my website, https://kendoophotography.wordpress....d-portraiture/
    Ken
