Page 11 of 11 FirstFirst ... 9 10 11
Results 501 to 543 of 543
Thread: "Capturing Infrared"
  1. #501
    Senior Member darr's Avatar
    Jan 2009
    North Florida
    855
    Re: "Capturing Infrared"
    First post in this thread. After looking at everyone's images here I decided to buy a used Fuji X-E2 and have Lifepixel convert it to Super Color. I am not new to IR, but I am new to color IR. I have in the recent past used one of my SD1M with the blocking filter removed (user can easily remove and reinstall) and a R72 filter for black and white. Even though once the blocking filter is removed and the SD1M can become super color 590nm ready, I would still need a filter and the SD1M has no live view. For black and white it is adequate, but I want live view for color. I did my first IR photography way back in the early 80s with Kodak high speed IR film and an A25 filter. It is much better today with mirrorless cameras.
    The image was made shortly after I received the camera from the UPS guy and then walked around my back yard snapping away. I used an ExpoDisc and made a custom WB moments prior to shooting. Once the images were taken into Lightroom (LR), I noticed one of the WB sliders was maxed out. I then decided to download Adobe's DNG Profile Maker and made a camera calibration profile for use in LR. Then I took the first image and used the camera calibration profile, selected all the other images from the shoot and synced the camera calibration for them all. LR saves me so much time when I know what I need to do. Once this image was chosen, I took it into Photoshop and used Topaz filters to adjust the color, add a texture and a bright spot with haze so it looked like the sun was behind the tree which in reality it was on the other side of the property.
    Thank you to everyone contributing to this thread and I hope to be adding here over time.
    Kind regards,
    Darr
  2. #502
    Jan 2009
    North Florida
    855
  3. #503
    Dec 2014
    159
    Nikon S1 IR, mod from KolariVision
    handheld street
    "Wet Eco-system"
    "Crossing while Green"
    "Transparencies in IR"
  4. #504
    Wisconsin
    3,533
    118
    Quote Originally Posted by darr View Post
    Darr,
    Beautiful!!!
    I set my white balance by shooting green grass. You might want to compare a scene using both green grass and expodisc for setting the white balance.
    I use a Sony A7II LP converted, but I have heard that the Fuji's make excellent IR cams when converted.
    If you want to max the color that you have to work with, you might try using the convert to Profile command in PS to go to the LAB space (not Image>mode>LAB). You can use the curve command to increase the sat, lum, hue and to white balance. After coming back to PS, then you can use Topaz, Nik or whatever you like to work with the color.
    Looking forward to seeing more from you!
    Cindy
    -Cindy
    www.cindyflood.com
    www.flickr.com/cindyflood
  5. #505
    Wisconsin
    3,533
    118
    Quote Originally Posted by Satrycon View Post
    handheld street
    "Wet Eco-system"
    I love all of the detail and the snappy conversion!
  6. #506
    Dec 2014
    159
    thank you..its a small nikon i bought from kolari vision..to experiment with..now that i know what can be done ill get a bigger FF or APS-C camera at some point..probably canon
    Quote Originally Posted by Cindy Flood View Post
  7. #507
    Wisconsin
    3,533
    118
    I have seen that little Nikon on Kolari's web site and been tempted by the idea of having it in my car, pocket or purse. Did you have to do a lot of post to get the files to look like this? Is noise a problem?
  8. #508
    Dec 2014
    159
    nope not a huge amount of post..i don't use PS, only lightroom, i setup a profile using the dng profile editor... results are much nicer and seem to have a wider "range" if one uses a not too bright and not too dull/dark green plant in the sun for the original WB...i realised shooting the right kind of green color [plant] really makes a difference.
    the S1 is definitely not good for low light evening/night shots..very noisy at higher ISO..
    ill probably get an a6300 at some point that should be good enough for most IR shots that id take, mainly in the street
    "After the Rain" nikon S1 IR
  9. #509
    Dec 2014
    159
    Nikon 1 S1 IR 720nm
    Sunrise in IR,, very nice details.
    Sunrise in InfraRed..Stage01
    Sunrise in InfraRed..Stage02
    Sunrise in InfraRed..Stage03
    Sunrise in InfraRed..Stage04
  10. #510
    Dec 2014
    159
    Nikon 1 S1 IR 720nm
    "Urban Tree"
    "Art in the Street"
  11. #511
    Dec 2014
    159
    Nikon 1 S1 IR 720nm
  12. #512
    Wisconsin
    3,533
    118
    Point Iroquois Lighthouse
    Brimley, Michigan
    Sony A7II FS, Canon 20mm FD, 720nm
    Click image for larger version.
    -Cindy
    www.cindyflood.com
    Likes 9 Member(s) liked this post
  13. #513
    iiiNelson's Avatar
    Sep 2008
    Texas/California/North Carolina
    2,848
    Haven't posted anything in awhile. Here are some shots I took from last weekend from the Scott Kelby Worldwide Photowalk last weekend. All with my A7R-FS and 35/1.4 Distagon + Kolari IR590 filter.
    Photowalk IR by Tre Nelson, on Flickr
    Photowalk IR-10 by Tre Nelson, on Flickr
    Photowalk IR-9 by Tre Nelson, on Flickr
    Photowalk IR-8 by Tre Nelson, on Flickr
    Photowalk IR-7 by Tre Nelson, on Flickr
    Photowalk IR-6 by Tre Nelson, on Flickr
    Photowalk IR-5 by Tre Nelson, on Flickr
    Photowalk IR-4 by Tre Nelson, on Flickr
    Photowalk IR-3 by Tre Nelson, on Flickr
    Photowalk IR-2 by Tre Nelson, on Flickr
    Priolite Ambassador | Sony Visible Light & IR Photographer
  14. #514
    Senior Member f6cvalkyrie's Avatar
    Feb 2009
    Belgium
    1,576
    29
    A beautiful sunny day, today, so it was time for a walk in my neighbor's garden :-) :-)
    Full spectrum Panasonic G1 with 720 nm external filter ...
    C U,
    Rafael
    E-M1/GH2/G1 Full Spectrum & lots of lenses
    http://www.flickr.com/photos/f6cvalk...th/9226689839/
  15. #515
    Jan 2009
    North Florida
    855
  16. #516
    Registred Users MoJo's Avatar
    Jan 2008
    Santa Fe
    210
    using the fuji x100-T, 72 filter, hand-held......
    Attached Images Attached Images
    My photoblog: http://josefskye.tumblr.com
    Friend me on Facebook: Josef Tornick
  17. #517
    Dec 2014
    159
    Sony ILCE-5100 mod>850nm
    E PZ 16-50mm @F3.5
    ISO3200 Night
  18. #518
    Dec 2014
    159
    E PZ 16-50mm @F4
    ISO100
  19. #519
    Dec 2014
    159
    E PZ 16-50mm @F5.6
    ISO100
  20. #520
    Dec 2014
    159
    E PZ 16-50mm @F4
    ISO100
  21. #521
    Nov 2010
    Auckland, NZ
    190
    Hi all, I shouldn't have looked at this thread. I am now going to order a A7II from KEH and get it sent to LP and get the SuperColour Mod. My question is I am a LE shooter and want to add IR, use A7rII plus Loxias, have looked most of this thread and haven't seen hotspot thoughts on the loxias, any thoughts?
    David
    Auckland, NZ.
  22. #522
    Wisconsin
    3,533
    118
    Quote Originally Posted by Hausen View Post
    I use a LifePixel A7II full spectrum. I know that the 16-35 FE that I had did not have bad hotspots, 24-240 FE does. I have been using Voigtlander 12 and 15 and Canon FD 20 and 24 without a problem, but have never tried Loxia's. Please report how the Loxia's work out.
  23. #523
    iiiNelson's Avatar
    Sep 2008
    2,848
    No idea how the Loxia's will fair with IR but the Batis' aren't great.
  24. #524
    Nov 2010
    Auckland, NZ
    190
    Now that I have been looking into IR a add pops up on fb for Kolari Vision and it mentions a hot spot reducing coating on their conversions, has anyone used this, does it work?
    David
    Auckland, NZ.
  25. #525
    Wisconsin
    3,533
    118
    I have no experience because I sent my camera to LP just before the Kolari hot spot reducing filter became available. I heard from one person on a forum that I belong to (who had it put into A7II) that it was not perfect. I've read from another review that it does not get rid of a hot spot, but reduces the effect by one to two stops. By that they mean that if a hot spot would show up at f/8, then it would now not show up until f/16. Here is the reference: http://infraedd.blogspot.co.uk/2016/...t-issue_3.html
  26. #526
    Dec 2014
    159
    E PZ 16-50mm @F3.5
    ISO200
  27. #527
    Dec 2014
    159
    https://kolarivision.com/articles/lens-hotspot-list/
  28. #528
    Nov 2010
    Auckland, NZ
    190
    The reason for my question was I couldn't see the Loxias on that list. Ordered a readymade A7II from KV today with 590nm conversion. Can't wait to be part of the thread. Travelling to some of NZs more scenic regions over summer break and looking forward to shooting with IR as well as my normal BNW LE.
    David
    Auckland, NZ.
  29. #529
    Wisconsin
    3,533
    118
    Those lists only exist because people report their findings, so please write in with any findings.
    You will be very happy with the 590nm filter. (You probably know this, but others reading may not) you can add 665nm, 720nm, 830nm, etc. on the front of the lens to get other effects.
    I can't wait till you post some photos!
    -Cindy
    www.cindyflood.com
  30. #530
    Dec 2014
    159
    E PZ 16-50mm @F3.5
    ISO100
    "morning light"
  31. #531
    Nov 2010
    Auckland, NZ
    190
    Smile Re: "Capturing Infrared"
    Thanks Cindy, thats why I went the 590nm route. Also I am primarily a BNW guy and I think the OTT colour of the 590nm will be a welcome alternative to LE BNW. I am really looking forward to it arriving as well
    David
    Auckland, NZ.
  32. #532
    Dec 2014
    159
    E PZ 16-50mm @F10
    ISO250
    "gentle giants"
  33. #533
    Dec 2014
    159
    E PZ 16-50mm @F8
    ISO100
  34. #534
    Dec 2014
    159
    E PZ 16-50mm @F6.6
    ISO100
  35. #535
    Dec 2014
    159
    E PZ 16-50mm @F5.6
    ISO100
  36. #536
    Dec 2016
    Essex, UK
    8
    I shoot most of my IR with a full spectrum converted mirrorless camera. The EVF makes framing easy even with a visibly opaque filter on the lens & all focusing is via the sensor so now issues over focus shift. I play with a wide variety of filters
    Crocuses by IR2 by Mike Kanssen, on Flickr
    Andrew Jordan - Infra red panning by Mike Kanssen, on Flickr
    wrabness P1020311 by Mike Kanssen, on Flickr
    aP1040285 by Mike Kanssen, on Flickr
    Infra red Photowalk by Mike Kanssen, on Flickr
    Bee in infra red by Mike Kanssen, on Flickr
    and without filters too, where the IR can change the image significantly. (The teams uniforms match the cars paint in visible light)
    Full Spectrum grid by Mike Kanssen, on Flickr
    Mike
  37. #537
    Los Altos, CA
    10,285
    1022
    Petro --
    I really like your Crocuses (Croci?) shot
    And welcome to the forum!
    home: www.getdpi.com
  38. #538
    Wisconsin
    3,533
    118
    Welcome, Petrochemist! I, too, shoot with full spectrum mirrorless! That is a great first post.
    -Cindy
    www.cindyflood.com
  39. #539
    Nov 2010
    Auckland, NZ
    190
    Have been playing around with my recent purchase of Sony A7II, 590nm mod with HS coating from Kolari. This is one of my favourite places, Whatipu in Auckland. Lens is Zeiss 15 2.8ZF2. Have been playing with my Loxias 21mm and 50mm with good results as well.
    David
    Auckland, NZ.
  40. #540
    Apr 2013
    227
    Here's one from Cloudland Canyon in NW Georgia this fall. FS A7R, 55mm FE1.8, 720nm filter. Processing in Silver Efex 2.
  41. #541
    Shashin's Avatar
    May 2011
    Maine, USA
    4,147
    132
    Fuji Xpro 2, 23mm f/2, and B+W 093 IR filter (830nm cut on (if you want to shoot IR...). The color is straight from the unconverted camera after WB in post.
    And in real life...
    And obviously not from Maine--if you want to shoot chlorophyll up here, you need to go to the local produce department.
    Will
    http://www.hakusancreation.com
  42. #542
    Apr 2013
    227
    Marshall's beach from this past summer. Full spectrum A7R, 55mm 1.8, 720nm filter.
  43. #543
    Nov 2010
    Auckland, NZ
    190
    Summer holiday season here in New Zealand. One of my favourite parts of the country is the Aoraki-Mt Cook area. Mt Cook is New Zealand's highest mountain and the whole area is just gorgeous with the sSouthern Alps and the most amazing blue/aqua lakes. This is pic is from a popular track, The Hooker Valley Track, this is at the top and Mt Cook is the peak in the distance. Sony A7II Zeiss 15 2.8Zf.2 590nm.
    David
    Auckland, NZ.
