Results 1 to 5 of 5
Thread: wide on the G1
    May 2009
    Southport, Australia
    1,429
    wide on the G1
    Hi
    lenses which cover wide on the G1 are not so many, to me there is the Oly 9-18 and the Panasonic 7-14
    I've got the 9 so I thought I'd do a little compare of size with the 7-14 and write a brief review of the 9-18 on my blog
    here.
    Jun 2009
    San Diego, CA
    776
    Re: wide on the G1
    Nice article, but I'm confused about this statement:
    "Essentially a wide lens such as a 24mm on a Full Frame system is a 12mm on a 4/3rds."
    Isn't it the other way around? A 24mm on a full-frame 35mm camera becomes 48mm on the m4/3? That's why the 7-14 lens (35mm equivalent) gives you 14-28 on the G1, a 90mm lens (35mm equivalent) gives us 180mm on the G1, etc., etc. Please forgive my ignorance if I'm mistaken.
    Senior Member RonSmith's Avatar
    May 2009
    Michigan USA
    432
    Re: wide on the G1
    Quote Originally Posted by photoSmart42 View Post
    You're correct.
    The sentence should more accurately say that a 12mm on a 4/3 gives the field of view that a 24mm does on a full 35mm frame camera.
    Ron Smith
    Flickr
    May 2009
    1,429
    Re: wide on the G1
    Hi
    I see the issue, what I am saying is that a 24mm on a Full Frame system equals a 12mm on a 4/3rds (or needs) on a 4/3rds system.
    I get frustrated with people's never ending attempts on this issue because I come from using several formats (Large, 120 6x9 and 35mm) so I think about angle of view (lens and format)
    How about:
    "Essentially when you want a wide lens such as a 24mm on a Full Frame system you neet to use a 12mm on a 4/3rds."
    May 2009
    1,429
    Re: wide on the G1
    Ok ... made a few changes ... that should clear up that point.
    thanks for the feedback
