Results 1 to 5 of 5
Thread: Anyone with experience fixing a stuck aperture (25mm SOM Berthiot C-mount)
    Sep 2009
    233
    Hi all,
    I just received a 25mm f/1.9 Lytar on EBay. Focus ring is smooth, but aperture ring is absolutely stuck at f/4.
    Is there something I'm missing with the C-mount (like perhaps there is some pin that needs to be pushed down to change aperture?) I don't have my c-mount adapter yet so haven't mounted the lens to my G1.
    Has anyone ever taken apart such a lens (or similar) to fix this? The aperture ring is near the base of the lens, so I'm hoping that's the right path.
    I got it for pretty cheap, so would much rather fix it than return for refund (I have contacted the seller to hopefully get a partial refund though.) I guess I could also try to find a shop to fix it, its amazing in this 'disposable' age such an idea seems quaint.
    Thanks for any pointers.
    Irwell
    Re: Anyone with experience fixing a stuck aperture (25mm SOM Berthiot C-mount)
    Quote Originally Posted by madmaxmedia View Post
    Hi all,
    Can you post a picture(s) of the lens,
    maybe someone can help you,
    Sep 2009
    233
    Here are some pics of the lens-
    Sep 2009
    233
    LOL, my greater issue is that this does not seem to be a C-mount lens? (as it is unthreaded)
    Does anyone know what this is? If so, do you know if the lens has to be mounted for the aperture to be adjusted?
    Sep 2009
    233
    Okay, from looking at other pictures of the same lens, it looks like my lens is literally missing the mount piece. I'm guessing that someone tried to fix the lens, but then gave up and forgot to put the last piece back on.
    I've arranged a refund with the seller. Thanks!
