Results 1 to 18 of 18
Thread: 20mm/1.5 c-mount SOM Berthiot
    Senior Member petermcwerner's Avatar
    Jan 2009
    Geneva, Switzerland
    511
    I was amazed at the sharpness and beautiful bokeh of this lens fully open.
    A little beauty, and it brings only 150 grams on the scale
    Here, the original full frame photo:
    Ucropped 4:3 photo with heavy vignetting
    1/1600 @ 1.5 - ISO=100 - Developed in RAW Therapee
    Crop
    Peter Werner
    Leica M8, R9+DMR & Digilux 2; Nikon D700; Panasonic FX01, FX150 & G1; Samsung TL350 (WB 2000)
    Vivek's Avatar
    Apr 2008
    Netherlands
    13,602
    21
    Re: 20mm/1.5 c-mount SOM Berthiot
    Peter, The noise at the base ISO is quite striking. Was your battery towards its end?
    Jan 2009
    Geneva, Switzerland
    511
    You are right about the noise, thanks for your suggestion. The icon in the viewer still shows full load but I shall reload it.
    Peter Werner
    Jan 2008
    North Vancouver, BC
    1,168
    Vivek,
    Are you saying that the noise gets worse as the battery depletes? That's the first time I've ever heard this. What leads you to that conclusion? I would have expected the battery interface to have at least some power regulation. Maybe on the last shot of a dying battery you might expect some funkiness, but otherwise???
    Jan 2009
    Geneva, Switzerland
    511
    Vivek, Simon,
    I checked again if the ISO was accidentally changed when activating the MF Loupe, but no. This picture was the last I took today with the G1. It had not been touched since and the ISO was still on 100.
    The white orchid flower was lit by the sun, the background was in the shade and thus underexposed. Might this explain the noise?
    Cheers
    Peter
    Peter Werner
    Vivek's Avatar
    Apr 2008
    Netherlands
    13,602
    21
    Quote Originally Posted by simonclivehughes View Post
    Vivek,
    Simon,
    I always have trouble when the battery (the official, "special" Pana battery) goes from 3 stripes to anything lower. With one stripe, things (noise) start to go haywire.
    Vivek's Avatar
    Apr 2008
    Netherlands
    13,602
    21
    Quote Originally Posted by petermcwerner View Post
    Vivek, Simon,
    Cheers
    Peter
    Peter, Given the lighting, it could be flare that obscured the metering. You can barely see the yellow as yellow in the Orchid.
    Jan 2008
    North Vancouver, BC
    1,168
    Simon,
    Interesting... I haven't noticed this myself, but then I haven't been looking for it either.
    Aug 2009
    1,642
    Kern Switar 25mm F1.4
    May 2009
    Southport, Australia
    1,429
    I'm also seeing an ugly grid pattern in the upper right corner
    I'd ditch your raw converter if that was 100iso and not drastically underexposed
    my first thoughts are that to get the white not clipping (looking at the lighting) you've undertaken some application of curves or such to push up the shadows
    not sure if that helps but keep having fun! :-)
    Jan 2009
    Geneva, Switzerland
    511
    Thanks to all for the comments. I shall see to upload a better example next week,
    Cheers
    Peter
    Peter Werner
    Aug 2009
    1,642
    Quote Originally Posted by hakkalo View Post
    Peter ,sorry for posting the wrong picture.
    I re-submit this autumn leaf taken with Som Berthiot Pan-Cinor 17---85mm F3.8
    Jan 2009
    Geneva, Switzerland
    511
    SOM Berthiot 20mm/1.5 on G1 (Crop) - 1/2000 @ 1.5 - ISO=100 - RAW Therapee
    Peter Werner
    Jan 2009
    Geneva, Switzerland
    511
    SOM Berthiot 20mm/1.5 on G1 (Crop) - 1/3200 @ 1.5 - ISO=100 - RAW Therapee
    Peter Werner
    Jan 2009
    Geneva, Switzerland
    511
    SOM Berthiot 20mm/1.5 on G1 (Crop) - 1/800 @ 1.5 - ISO=100 - RAW Therapee
    Peter Werner
    Jan 2009
    Geneva, Switzerland
    511
    SOM Berthiot 20mm/1.5 on G1 (Crop) - 1/4000 @ 1.5 - ISO=100 - RAW Therapee
    Peter Werner
    Jan 2009
    Geneva, Switzerland
    511
    Peter Werner
    ChrisJ
    There's some heavy vignetting with that lens, by the time you've cropped the vignette out it's not a 20mm lens anymore.
    I've never heard of a low battery causing more noise, but as the voltage decreases the current has to increase (Ohms Law) so, as it's the current which causes the heat in the sensor which causes some of the noise, I suppose there may be something in it, but I've never noticed it yet.
    Chris
    Chris
