Results 1 to 3 of 3
Thread: External flash options for G1
    Senior Member f6cvalkyrie's Avatar
    Feb 2009
    Belgium
    1,643
    29
    I have seen several undetailed setups with external flashes posted here by different people.
    I am looking currently to get me some more light for the winter.
    My primary use would be for macro-shooting and portret.
    I own an very old professionnal flash setup from "Pro", that I could connect to my Nikons via the usual sync cable. Is there an accessory for the G1 that could receive this sync cable ?
    TIA for your info !
    Rafael
    E-M1/GH2/G1 Full Spectrum & lots of lenses
    http://www.flickr.com/photos/f6cvalk...th/9226689839/
    Aug 2009
    Sydney, Australia
    347
    Re: External flash options for G1
    One of these might do the trick... Link
    May 2009
    Southport, Australia
    1,429
    Hi
    I also use an older flash, I use a Metz, and one of these.
    Cheap as chips and does the trick to sync. I find the wireless to be a benefit as I can move without getting tangled. You could then put optical slave triggers on additional strobes as required to sync them in with the main "paf"
    I went back this way after my 10D refused to work with my 430EZ based flash system for my EOS outfit. I was most pissed off with that and it kept me from moving to digital for a few years after the E-TTL stuff started.
    I don't like being burnt like that (and know to some extent how the FD owners felt)
