Results 1 to 4 of 4
Thread: Sensor Cleaning
    Jan 2008
    Toronto, Canada
    3,026
    1117
    Sensor Cleaning
    I have a G1 and an E-P1 and I am changing lenses all the time on both bodies.
    By a fluke I discovered how dirty the sensor was on my G1. I'm now researching the best way to clean it - I would love to know people's experience with this.
    Keith
    Senior Member Brian Mosley's Avatar
    Jan 2008
    2,394
    17
    Re: Sensor Cleaning
    Hi Keith,
    I just used a sensor cleaning pen - the AA filter is pretty tough. Very easy to clean, being such a short registration distance and open.
    Good luck! I cleaned my G1 and E-P1 recently.
    Cheers
    Brian
    Member slau's Avatar
    Jun 2009
    AB, Canada
    185
    Re: Sensor Cleaning
    Quote Originally Posted by woodmancy View Post
    Keith
    The sensor of my G1 was good when it came in, but the GH1 sensor needed a complete 'wet' cleaning immediately. I used and have been using the same Eclipse optical cleaner and the Pec Pad for all my digital cameras. Actually cleaning the sensor of my GH1 is the easiest as the sensor is so exposed up front.
    http://www.cleaningdigitalcameras.com/methods.html
    Stephen Lau
    Calgary, Alberta, Canada
    http://www.pbase.com/stephenl
    Aug 2009
    Sydney, Australia
    347
    Re: Sensor Cleaning
    I use the Lenspen SensorKlear pen and it works well and reasonably priced. I got mine in a kit with 3 spare cleaning tips/caps. Each is claimed to last about 50 cleans and at the rate I am going that should last me close to the 22nd century.
    You get rid of all the crap first by holding the camera sensor down, and blow out the loose crap with a decent rocket blower
    With the camera facing down, run through several cycles of the cameras sensor cleaning thingie (with the Olympus cameras that just means power it on and off a couple of times). That will dislodge any loose stuff that the blower didn't get (there shouldn't be any).
    Then work your magic with the SensorKlear pen.
    I have never had a situation where the SensorKlear didn't work and no need for wet cleaning.
