Results 1 to 12 of 12
Thread: Leica Screw Mount to Micro Four Thirds?
    Senior Member Mike Woods's Avatar
    Bristol, UK
    1,473
    Hi
    A very quick question if I may. I'm interested in getting an Ultron 35mm f1.7 for my E-P1. I understand this is a Leica Screw Mount, and simply need to know what adapter I need to mount directly to my E-P1.
    I think in the 'early days' you would have needed two adapters to do this, but I'm hoping a single adapter is now available which will do the trick?
    Many thanks in anticipation.....
    Mike
    Senior Member JBurnett's Avatar
    Aug 2009
    Bridgewater, Nova Scotia
    530
    2
    Re: Leica Screw Mount to Micro Four Thirds?
    Several companies sell these on eBay. I`ve had good luck with adapters from JinFinance (RJ), and he makes a LTM to m4/3 adapter. Do a search on M39 and G1.
    Best regards,
    John.
    http://jburnett.ca
    Bristol, UK
    1,473
    Many thanks John,
    Really appreciate the quick reply.
    Regards
    Mike
    Member laptoprob's Avatar
    Apr 2009
    Haarlem
    131
    3
    Both RJ and Hawke have them. No real difference, both work fine. Some adapters have a separate inner part that can be loosened and rotated if needed. The Ultron works best if you add a baffle with a ca. 13mm opening at the rear of the lens. This increases corner sharpness.
    "You live and learn; at any rate you live" (Douglas Adams)
    Bristol, UK
    1,473
    Thank you for the info - ordered from RJ this evening.
    Mike
    Bristol, UK
    1,473
    Well, adapter arrived and now first manual lens purchase came yesterday, a mint 35mm 1.7 Ultron.
    I know there's been some debate recently about 'why' manual focus lenses on micro 4/3 but......doesn't she look pretty
    Regards
    Mike
    Aug 2009
    530
    2
    Very pretty indeed! Let us know how she performs, too.
    Best regards,
    John.
    http://jburnett.ca
    Wisconsin
    3,581
    118
    It looks great. Please let us know how the corners perform...there have been instances of smearing with the 28 f/2 Voigtlander, but I use a Voigtlander 28 f/1.9 with good results.
    Mar 2008
    Istanbul/Turkey
    339
    4
    Cindy,
    I was considering to buy the 28/2 Voigtlander, since the 28/1.9 is the discontinued model. (But it's still available).
    I will use the lens with my M8, as well as M4/3.
    May I have your comments about using these with the M8? Many people prefer the 28/2 but I feel from photos downloaded from internet, that 28/1.9 may be preferable.
    Thanks in advance,
    Seyhun
    H3DII-31, 5DII, M8, NEX-3 and Camera collection
    http://seyhun.com
    Facebook Page
    Senior Member ggibson's Avatar
    Oct 2009
    SF Bay Area
    743
    Beautiful, Mike. That's a nice looking combo! I just purchased an adapter set for C mount + M39 + M42 that I'm looking forward to using. Post some photos with it when you get a chance!
    Wisconsin
    3,581
    118
    Quote Originally Posted by s.agar View Post
    Cindy,
    Thanks in advance,
    Seyhun
    Seyhun,
    The Leica 28 f/2 is the gold standard. I had it in the past, but now I have the 28 f/1.9 Voigtlander and the 35 f/2 Leica for my M8. I love the Voigtlander. Mine is very sharp and is excellent with an IR filter (no hot spots) on the M8. I have not used the Voigtlander 28 f/2. I understand that it is smaller than the 1.9, but I'm so happy with the 1.9 that I wouldn't consider switching. It works well on my G1's. It is nice to stick a G1 body and the adapter in the camera bag when I'm taking out the M8.
    Maybe someone who has used both Voigtlander 28's will post.
    Mar 2009
    Miami
    164
    Quote Originally Posted by Cindy Flood View Post
    Seyhun,
    I have tried both Voigtlander 28mm lenses and I can assure you that older 28mm f1.9 Asph is better performer on m4/3rd. It has less smearing, probably because the rear element is not as close to the sensor as newer 28/2.
    You can still see a bit of smearing at infinity, but not bad. Get it while you can, unless you want to go with high-end cine, but those will cost you much more.
    I'm not huge fan of Voigtlander overall, but they do make some excellent lenses and Lanthar 90mm f3.5 APO is one of them. (excellent for the money)
