Thanks, Peter. Actually, before the upgrade the MF assist stayed on indefinitely from what I can tell unless the OK button is pressed.It previously stayed on for around 8s or until you did a half press of the shutter button (from vague recollection).
I had a suspicion that they may have done some AF tweaking and early reports indicated that was the case. The first thing I did was test the change and was very happy with the improvement in focus speed of the Panasonic 20mm lens.I'm amazed by the fact that most people did not use the MF assist option but still upgraded the firmware. Why???
