Results 1 to 15 of 15
Thread: Olympus EP-2 (or EP-1) and Lightroom
    Jul 2008
    111
    I'm thinking of buying an EP-2. Already have the Panasonic G1. I shoot RAW. Does lightroom apply the same automatic chromatic aberration and distortion corrections to EP-2 images as it does with G1 images? . . . With the 20mm f1.7, it probably wouldn't be that big of an issue, but I expect with the Panasonic 14-45mm or 7-14mm lenses, I'm much better off with having the automatic lightroom corrections applied.
    Thanks in advance, Howard
    Terry's Avatar
    New York City
    6,955
    1145
    Re: Olympus EP-2 (or EP-1) and Lightroom
    Yes and no. It isn't Lightroom dependent it is Oly dependent. Oly only sends distortion correction information to the Raw converters and does not correct for CA. Panasonic corrects distortion a little more fully than Oly but that has not a big deal at all.
    Godfrey's Avatar
    Jan 2009
    Near San Jose, California
    7,929
    To expand on Terry's answer:
    The lens correction metadata is in the lens. It is communicated to the body when the lens is mounted and an exposure is made. Whether that metadata contains rectilinear correction data or chromatic aberration data is specific on a lens by lens basis. What I've found so far with the lenses I've tried:
    Summilux-D 25/1.4 ASPH - CA correction data
    Lumix G Vario 14-45, 7-14, 45-200 and 45, 20 mm - RC and CA correction data
    M.Zuiko 14-42 and 17 mm - RC data
    At that point it's up to the body to use the data. So far, all the Panasonic bodies embed both RC and CA correction information into the .RW2 files. All the Olympus bodies embed only the RC correction information.
    Lightroom v2.6 processes the files from all current mFT bodies with all available lens correction metadata applied.
    jonoslack's Avatar
    East Anglia & Cornwall (UK)
    11,778
    At that point it's up to the body to use the data. So far, all the Panasonic bodies embed both RC and CA correction information into the .RW2 files. All the Olympus bodies embed only the CA correction information.
    Hang on Godfrey - don't you mean that the Olympus bodies only embed the RC correction data (and NOT the CA correction)?
    all the best
    Just this guy you know
    Godfrey's Avatar
    Jan 2009
    7,929
    thanks ... yes, I corrected it. Brain fart ... ! ;-)
    Jul 2008
    111
    Oh -- that's a big difference. I find chromatic abberation the most difficult to correct.
    jonoslack's Avatar
    11,778
    Sorry - I can't delete my post now . . . . I always like it when someone else makes the kind of mistake that I do all the time
    jonoslack's Avatar
    11,778
    Quote Originally Posted by httivals View Post
    Of Course
    you could always use Capture one, which is fantastic with CA . . . . . .
    Life is so simple
    Austria, close to Vienna
    3,871
    I started using C1 today for EP2 RAWs and it works perfect!
    Godfrey's Avatar
    Jan 2009
    7,929
    Lightroom makes correcting CA pretty easy, and it's particularly easy when you're correcting it in raw image files. The CA correction sliders are in the Develop module, Detail panel, one for R-G and the other for B-Y.
    A tip: hold the Option or Alt key down when you click and drag them, and the image will desaturate to just the colors you are trying to mesh while you're doing the adjustment.
    Another tip: find an edge at a corner and set the display magnification to 1:1.
    Once you've got the adjustment set for a particular lens and f/number setting, make a Develop preset for those adjustments. Then, in the future, when you use that lens you just apply the preset and you're done.
    I have CA presets set up for the Olympus 25, 11-22, and 35 Macro. Makes it very easy to work with all of them.
    Jul 2008
    111
    Yes, but that assumes that the CA is uniform throughout the image, which I doubt, especially for a lens like the Panasonic 7-14mm -- one of the great lenses of the m4/3 system. With the Panasonic G1, there's no visible CA when shooting in RAW and using Lightroom.
    1,860
    I think all the m4/3rds Panasonic lenses have CA correction in LR--if I'm not mistaken, I think Godfrey is just referring to some lenses that don't have automatic CA correction in LR--legacy 4/3rds lenses.
    Daine
    Godfrey's Avatar
    Jan 2009
    7,929
    Quote Originally Posted by Diane B View Post
    All the Panasonic mFT lenses have CA correction in their firmware. Only the Panasonic bodies use it and embed it in the raw files for Lightroom to use.
    Lateral chromatic aberration shifts, on lenses which don't have the correction in firmware, are predictable across the field of view in my experience. They operate on a curve that the software takes into account as you move off the lens axis. The reason for going to an edge is that the adjustment is most visible there.
    I can't speak for the 7-14 specifically... I have a few exposures made with one but I use the G1 so the CA is corrected automatically by LR based on metadata in the raw files.
    1,860
    I should never say 'I think.....' when I know that LOL. And--I should learn to type my name correctly.
    Diane
    Jan 2010
    519
    Are RC metadata written to RAW files by Olympus and Panasonic exactly the same? 100%?
    Or may be even slightly - different? Has it anytime been published officially? Or we only guess?
    Additional question - what is written in RAW: metadata about distortion, or info how to correct it?
    If 1st, than yes, results from Olympus and Panasonic should be the same.
    Is 2nd, than it could mean that even for the same lens, with the same distortion - the receipt, guide for LR - could be different.
    Another words - will the same lens give always exactly the same results when attached to Olympus and Panasonic body - and RAW opened in LR?
    (I mean RC, not CA, which may not be present for Olympus).
    PS:
    Oryginal question that I started to think of is: could it be possible, that micro 9-18mm attached to Panasonic would give sharper edges, than to Olympus?
    PPS:
    as we know, Panasoni LX3 is also being corrected by LR. Do you think it stores the same correction metadata in RAW - as u43 does?
    Best Regards!
