Results 1 to 15 of 15
Thread: New Low Profile c-mount adapter...
    Nov 2008
    3,848
    This adapter should allow bigger lenses to be fitted...
    http://www.japanexposures.com/2010/0...nector-s-slim/
    May 2009
    Southport, Australia
    1,429
    Re: New Low Profile c-mount adapter...
    thanks for bringing that up ... actually it looks similar to Hawkpeng's one
    but I didn't spot the price in that article ...
    Nov 2008
    3,848
    I have a Hawk adapter, this new one appears to be lower profile on the edge, being completely flat. Not sure which lenses this may help...maybe MS Optical would know?
    May 2009
    77
    Very nice post monza, if I knew this was made, I should have kept my Fujinon TV zooms which needed this lower profile c-mount to achieve infinity focus. Darn! Oh, well! I think I may pick up this adapter to test out with another lowprofile lens. Maybe this will help with the Senko 50mm .95! Thanks again!
    Jun 2009
    San Diego, CA
    776
    It could help a lot of c-mount lenses actually if they built it correctly. The c-mount lenses don't fit completely flush against the bottom of the adapter, but sit on the lip that's near the center thread. From what I've measured on my c-mount lenses, that center section is about 0.5-0.6mm thick, and has a radius of about 15mm from the lens center. If this flatter adapter fits those dimensions, then it eliminates the inside interference issue. The flatter outer ring of the adapter can then eliminate the second interference issue, which is the edge of the lens mount in some cases. This promises to allow quite a few lenses to fit without machining.
    Here's a dimensioned drawing I did a few months back to help me figure out how much to machine off my lenses (to fit the Kipon C-mount adapter that's shown dimensioned at the top):
    Senior Member kds315's Avatar
    Sep 2009
    Weinheim, Germany
    1,441
    JPN10.500 approx USD116 plus shipping from Japan
    Member sangio's Avatar
    Feb 2009
    London, Ontario, Canada
    119
    24
    Thanks for the link Monza.
    I noticed on their site that they will custom fit a Cosmicar 12.5 f1.4 to this adapter. Does that mean that this lens will not focus at infinity without some machining?
    regards
    Santo
    Nov 2008
    3,848
    I believe that's correct, I have had a few Cosmicars and most needed some machining.
    Vivek's Avatar
    Apr 2008
    Netherlands
    13,606
    21
    Hawk Peng's adapter was offered initially for $15/-?! Price stabilized to where it is now after a few months.
    While I understand MS Optical's price, I can not understand why anyone would bother buying them.
    Feb 2009
    119
    24
    Just FYI, I wrote to the folks at Japan Exposures about their custom lens machining service.
    They tell me it would cost between $55 and $75 USD to machine a lens for a proper fit. So with the cost of their adapter, it would total around $175 to $195, not including shipping. I'm guessing it would be around $250 USD all in.
    They also indicated that turn-around time would normally be about one week.
    regards
    Santo
    Jun 2009
    San Diego, CA
    776
    Quote Originally Posted by sangio View Post
    regards
    Santo
    Sounds a bit ridiculous to put all that cash into a $25 lens, don't you think? It may not be pretty, but it's MUCH cheaper to grind the lens mount by hand. I guess it's worth it for a lens that costs over $1000, but even then I bet you can find a local machine shop that can do it for you for under $100.
    Feb 2009
    119
    24
    Quote Originally Posted by photoSmart42 View Post
    Yes, it's a bit pricey. I think I may get the hawk peng adapter and borrow a dremel grinding tool.
    regards
    Santo
    Senior Member Y.B.Hudson III's Avatar
    Jan 2008
    314
    soooo... what happens when my $25 lens out performs a $3,600 lens?
    Jun 2009
    San Diego, CA
    776
    Quote Originally Posted by Y.B.Hudson III View Post
    Not sure what that has anything to do with what I wrote. If it makes you feel better to spend $250 on a $25 lens that shoots like a $3600 lens, go for it. I'm happy grinding mine by hand. If I screw something up, I can buy another 9 lenses to get it right and still come out ahead of paying for having a single lens machined... At the very least, I certainly don't feel like having to ship a simple machining job to Japan when I have about 100 local machine shops in town hungry for work.
    alanwf
    I turned down the mount on my 12.5 1.4 cosmicar to fit into a generic C mount. We have a large “jeweller’s lathe” in my shop. Machine shops should charge under $100, but it is a bit tricky in terms of the three screw holes that mount the rear flange onto the lens. I needed to cut slightly into these holes (and still don’t have full infinity focus), even with also trimming down that .55mm step that one of the earlier poster’s mentioned. So this flatter adapter would help a lot.
    I don’t think my cosmicar is a good sample though; resolution is not a strong point. I do like the vignetting (mainly shoot square with it) and don’t mind the softness, but I find I tend to think of it when I want a “style” rather than a low light wide ange lens (which I still don’t have). I may get another sample just to try though—I ‘ve done all the work...
