Results 1 to 20 of 20
Thread: ERCSAM Cine lenses for m4/3?
    Alan Ang
    hi, just like to ask the experts here whether there's any way that we can connect the ERCSAM Cine lenses to m4/3?
    Alan Ang
    Re: ERCSAM Cine lenses for m4/3?
    anyone here has any experience with ERCSAM Cine lens?
    Alan Ang
    anyone?
    Alan Ang
    does anyone here has experience or some knowledge of ERCSAM lens?
    144
    you might consider showing a photo of the lens as it might be a private branded lens that might be identified by the image.
    Gothenburg, Sweden
    1,309
    Alan, searching info about Ercsam lenses on the Net provides nothing byt lenses for 8 and maybe 9.5mm film. Have you found a lens you think would work with a 13x17.3mm sensor?
    Senior Member LCT's Avatar
    317
    I had a 'Reflex 8' in the sixtees. There were no Ercsam lenses then if memory serves. Mine had a Schneider Variogon zoom lens but Angénieux zoom lenses were used on that camera as well (pic below).
    Alan Ang
    this is the lens that i found online... "Angenieux 9-36/1.4 K3 en monture ERCSAM"
    the seller claimed that it can be c-mounted... but he's not english speaking perhaps and i may not have grasped his full meaning as he might have meant to say lots of machining may be required or something of similar...
    attached is the only picture i have from him... can't see the base of the lens to know for sure of the mount type...
    anyone has any idea if we can do anything to modify this lens for c-mount? it looks like a great piece of lens to me...
    317
    Ercsam made only 8mm and 9.5mm cameras if i remember well so i doubt any of their lenses can cover the 4/3 format.
    Alan Ang
    Quote Originally Posted by LCT View Post
    you reckon there's no chance whatsoever to make it usable?
    317
    On a small sensor camera perhaps? I would ask Angénieux if i were you:
    http://www.angenieux.com/index.php?rub=13
    Alan Ang
    thanks LCT. i will check with them...
    in the meantime, if anyone else has some idea on how i can go about converting it to m4/3, please let me know. thank you everyone for helping.
    this lens is too beautiful to be junked... i want to make it work... :P
    Senior Member kds315's Avatar
    Sep 2009
    Weinheim, Germany
    1,441
    Most likely not IMHO, too small image circle as it is a wide angle.
    Alan Ang
    sigh... they haven't replied till date...
    Abbazz
    The Angenieux 9-36 zoom was designed for 8mm movie cameras. I doubt very much it would be of any use on a Micro 4/3rds camera:
    Cheers!
    Abbazz
    Alan Ang
    i dun mind serious vignetting... just wanna put it to some use... i wonder how difficult it is to machine a mount for it.
    Abbazz
    Quote Originally Posted by Alan Ang View Post
    We're not talking about serious vignetting here! You would only get a tiny circular image in the middle of the frame with a very thick black border. 8mm movie cameras have an image size of 4.8 x 3.5 mm, while Micro 4/3rds camera have an image size of 17.3 x 13 mm. I doubt the Angénieux zoom at its widest setting has an image circle much bigger than 7 mm but it would need 22mm to cover the Micro 4/3rds frame.
    Cheers!
    Abbazz
    Alan Ang
    Quote Originally Posted by Abbazz View Post
    Cheers!
    Abbazz
    arrgh... ok... looks like it will be junked afterall...
  19. #19
    Jun 2009
    San Diego, CA
    776
    You can always try reverse mounting it to use as a macro lens if you're intent on giving it some life beyond it's intended (and now obsolete) use. Only need a reverse mount filter thread for that as the adapter.
    -Dragos
    Panasonic GH1/G1, Canon FTb(n)/F-1, Mamiya C330F/RB67 Pro SD, Chamonix 45N-2, Nikon F5 + Assorted Lenses
  20. #20
    Alan Ang
    Quote Originally Posted by photoSmart42 View Post
    that is an excellent idea! i'll look into this asap...
