Results 1 to 3 of 3
Thread: 4/3->Micro 4/3 adapter: worth doing?
    Senior Member Peter Klein's Avatar
    Mar 2008
    Seattle
    375
    I have the old (and very good) 40-150mm f/3.5-4.5 tele zoom for standard 4/3. I could pick up the Panasonic 4/3 to Micro 4/3 adapter ($115 at B&H) so I could use the lens with my G1. I realize that it would not autofocus, nor would it be image stabilized.
    The question is, would it be worth doing? Has anyone adapted one of the longer 4/3 lenses to the G1 via one of these adapters, and how did it work out for you?
    --Peter
    New Member sarunas's Avatar
    Jan 2010
    Upper Valley, NH
    6
    Re: 4/3->Micro 4/3 adapter: worth doing?
    4/3 to m4/3 adapters work as expected... Contrast-detect AF speed and accuracy depend on the particular lens being adapted. If you like the lens, then it's definitely worth a try on m4/3.
    Senior Member Tullio's Avatar
    Nov 2009
    San Jose, CA
    403
    I really like my G1 but it is very unfortunate that 1) it does not accept all Zuiko 4/3 lenses in terms of AF (with the adpater) and 2) it does not have IBIS. To me #2 is a killer when using long FL lenses. Unless you have other Zuiko lenses that will work properly with the adapter, I suggest you buy a non-electronic 4/3 to m4/3 adapter on eBay. It will work with the 40-150mm lens you have just the same as the electronic $114 adapter and cost you less than 1/2 the price.
    Tullio
