Results 1 to 18 of 18
Thread: Voigtlander Help Please
    richie15
    I have a GF1 and my lens line up is the Pana 7-14 (Landscape), 20 (Low Light and walkaround) and 14-45 (walkaround and landscape) all which are keepers. I also have the Voigtlander 75mm which I love (portrait and long length).
    A few months ago I owned a 35mm Ultron 1.7 and found this a but soft at f4 and below and having search the internet I concluded that if I am comparing lenses of 35mm and below with Panasonic lenses then the Panasonic lenses would probably be better so I will keep my Panasonic line up. Interestingly the 7-14 is the one I am struggling to come to grips with.
    I like my 75mm so much I have been exploring the idea of either a 40mm (1.4), 50mm (1.5) or the 50mm (1.1). The BOKEH on the 50mm 1.1 is stunning but it is a really expensive portrait lens and I wonder if owners use their lens for anything else?
    To sum up I wonder how much difference there is between the 50mm 1.1 and 1.5 or am I better off given my lens line up with the 40mm. Of course the alternative is the 45mm Pana/Leica????
    Any suggestions or help welcome.
    Subscriber Member Jonathon Delacour's Avatar
    Sydney, Australia
    454
    7
    Re: Voigtlander Help Please
    Quote Originally Posted by richie15 View Post
    The rule that "at 35mm and below, Panasonic native lenses are better than legacy lenses" only applies to Leica M and screw mount lenses, because of their short register. SLR lenses with focal lengths 35mm and under -- I have experience with Pen F, Minolta MC/MD, Hexanon AR, and Contax/Yashica lenses -- can provide superb results on m4/3 cameras. Even if you have to buy another adapter or two, you'll save money if you're willing to consider alternatives to the Leica mount.
    If the relatively small size of Leica M and screw lenses is important, then you might want to investigate Pen F lenses. I sold my Voigtlander Nokton 40/1.4 not long after I bought a Pen F 40/1.4. This may not apply to your usage but I also regard the 0.7 meter minimum focusing distance of the M-mount lenses as a significant disadvantage.
    richie15
    Quote Originally Posted by Jonathon Delacour View Post
    The rule that "at 35mm and below, Panasonic native lenses are better than legacy lenses" only applies to Leica M and screw mount lenses, because of their short register. SLR lenses with focal lengths 35mm and under -- I have experience with Pen F, Minolta MC/MD, Hexanon AR, Contax G, and Contax/Yashica lenses -- can provide superb results on m4/3 cameras. Even if you have to buy another adapter or two, you'll save money if you're willing to consider alternatives to the Leica mount.
    Thanks for your reply, I think I may be a bit Voigtlander blinkered at the minute. Given your experiences could you recommend any alternatives. Not that worried about the minimum focus distance as I was thinking of getting a Canon FD 50mm f3.5 macro to cover that.
    Pratamnak
    9,336
    2157
    Have a look at OM Zuiko lenses. I use a 50mm f/2.0 Macro for portraits, and it's incredibly sharp, even wide open. If you can live with a slower lens, the 50mm f/3.5 Macro is equally sharp, much cheaper and much smaller. I actually consider buying that in addition for the smaller size.
    Other OM Zuiko lenses that I use are the 35mm f/2.0, 100mm f/2.8 (a darling of a lens, but best used at f/4.0 or 5.6) and the 200mm f/5.0. The really good ones (besides the 50 macros) are the 90mm f/2.0 macro and 100mm f/2.0, but they are horribly expensive. The wides are nice too, but since they aren't wide on m43, a Panasonic or Digital Zuiko will mostly fo a better job for an equal amount of money.
    Jan 2008
    North Vancouver, BC
    1,168
    Richie,
    I have and use the CV 50 f1.5, the 75 f2.5 and the 90 f3.5 on my G-series bodies and love them all. The 50 f1.5, draws beautifully and has lovely bokeh. Personally, I tend to use the 75 more for portraits than the 50, but that's more the working distance than anything.
    I haven't tried the 50 f1.1 but I did have both the 35 1.7 and the 1.2 and the difference in size and weight is considerable, something that you might want to take into consideration.
    Hope that helps,
    Gothenburg, Sweden
    1,309
    Quote Originally Posted by Jorgen Udvang View Post
    (...) The really good ones (besides the 50 macros) are the 90mm f/2.0 macro and 100mm f/2.0, but they are horribly expensive.
    Ah..oh. I have a 90/2 for sale and it isn't horrible expensive at all. It is some money involved but you get more than you pay for!
    The OM50/2 is really excellent and while optically different to the ZD 50/2 it produces similar results, just so much better for manual focusing and critical checking of focus and DOF. But, as you say, with the adapter it becomes a bit large.
    /Jonas
    Gothenburg, Sweden
    1,309
    Quote Originally Posted by simonclivehughes View Post
    Richie,
    Hope that helps,
    I second most of all this. I sold my CV50/1.5 a day when I was more confused than usual. That was a bad move. I also love the CV75/2.5 which is a lens hard to beat in that FL. The 35mm lenses... well, I sold both, it is a facal length not really to my taste. But that is personal.
    I haven't tried the 50/1.1 as it is about a lot of money and I have other lenses in that FL which are fun and good enough.
    Generally I like lenses that are versatile. The 50/1.5 is "sharper" than the 40/1.4. There isn't a lot difference between them when it comes to the bokeh; they can both be a bit edgy sometimes but mostly works fine. Maybe a little advantage to the 50mm.
    I would check out images taken with the 50/1.5.
    my cents,
    /Jonas
    Vivek's Avatar
    Apr 2008
    Netherlands
    13,598
    21
    The "perfect" ones, as Jonathon mentioned, are the pen F lenses.
    I would definitely stay away from buying Leica M-mount lenses for the m/43rds.
    Gothenburg, Sweden
    1,309
    ...because?
    Vivek's Avatar
    Apr 2008
    Netherlands
    13,598
    21
    Better c-mount lenses are available.
    Gothenburg, Sweden
    1,309
    Mmm. There may be. But it is not a given. Do you have some suggestions for the OP? I would like to learn about a 50mm c-mount lens being better, or at least a real good value, compared to the CV50/1.5.
    Michiel Schierbeek's Avatar
    Mar 2009
    Amsterdam/Normandy
    4,055
    762
    Quote Originally Posted by Jonas View Post
    Or the Canon fd 50/1.4 Cheap and a terrific lens. I do have the VC Nokton 50/1.5 too. Nice, may be a bit sharper, but more expensive and I prefer the bokeh of the Canon fd, which is just a tad faster.
    Michiel
    Jun 2009
    San Diego, CA
    776
    My Canon FL 55/1.2 makes for a superb portrait lens.
    -Dragos
    Panasonic GH1/G1, Canon FTb(n)/F-1, Mamiya C330F/RB67 Pro SD, Chamonix 45N-2, Nikon F5 + Assorted Lenses
    dazedproductions
    I was all for getting a voigtlander as they are nicely priced and some of my first cameras were voigtlander rangefinders. The 40mm has somewhat busy bokeh though and the 50mm is quite large. I ended up going with the zeiss 50 f1.5 instead which is nice and compact and has nice bokeh IMO (but its somewhat more expensive). Size was important to me (I already have nikon f1.4 35/50mm lenses but they are larger than I wanted)
    richie15
    Quote Originally Posted by Michiel Schierbeek View Post
    Michiel
    I am going to explore this option as I have heard this as well. Yesterday I picked up the Canon 50mm f3.5 macro and will start with this and if I am impressed will try and track down a Canon 50mm f1.4, either way the cost of both of these lenses is going to be less than a CV 50mm 1.5 and def less than a 1.1.
    rachp
    I have a gh-1 now and had an ep-1 before. I have several voigtlanders - 50/1.1 and in nikon mount sl lenses I have 90/3.5, 180/4 and 75/2.5. I love all of my voigtlanders on the gh-1 but I don't think I would want to use the 50/1.1 on a smaller 4/3 body. I don't mind the size of the nikon mount sl lenses - they are very light and a good fit. I also love that I can use the sl lenses. on my nikon body.
    I am a big fan of voigtlander - they are a great value. If you can get around the mfd on the 50/1.1 then go for it!! It is a real WOW lens! Just look for a used one in the low $800s.
    I also have slII voigtlanders in Nikon mount - 20/3.5 and 40/2.
    jedperkins
    I have the Voigtlander 40mm f/2.0 SLII in the Pentax K mount. It is a pancake, so it is not too long even with the PK to mft adapter. I like it very much, the pictures are sharp even wide open.
    Apr 2010
    60
    The faster, the better. Having said that, i use the 85mm f1.2 and the 85mm f1.8 on a canon 5d and I sold the f1.2 lens because it ws just too heavy and the final results was not a world of difference in oof areas.
    on the m43 however, the difference between 1.1 lens and 1.5 lens is not too many grams, both are still quite light and the price difference is in hundreds and not thousands.
    i would go for the 1.1 lens.
