Results 1 to 7 of 7
Thread: PL-mount, Lens buying advise needed.
    jwestra
    I have the opportunity to but a few PL-mount lenses.
    The deal is for
    TWO identical: Schneider Cine-Xenon 75mm 1:2.2
    And one: Angenieux 12-120mm 1:2,2 with original case.
    All lenses are supposed to be in good condition without scratches.
    How much do you guys think these lenses are worth?
    mattlazz
    Re: PL-mount, Lens buying advise needed.
    Quote Originally Posted by jwestra View Post
    The deal is for
    Not good at putting dollar amounts on things, but Angenieux's have skyrocketed in price due to their quality. One issue though it whether it will cover the m4/3 sensor; I've yet to find a 16mm zoom lens that does. They all seem to have heavy vignetting.
    jwestra
    The Angenieux indeed shows heavy vignetting:
    http://forum.getdpi.com/forum/showth...nieux+12-120mm
    The other lenses are for 35mm and might be worth much more.
    Aug 2008
    Ontario, Canada
    96
    The 12-120 is a regular 16 lens. It doesn't cover the Super 16 frame at the wide end. That lens would have come with an Arri bayonet mount originally. I'm surprised it's been converted to PL.
    FYI, regular 16 is roughly 10x7.5mm. Super 16 is 12x7.5. Four Thirds is 17.3x13
    The 12-120 has a poor reputation in the Cine world, but a lot of that is due to the fact that they were ubiquitous on film-school and rental camera packages in the 1960s, 70s and 80s, so a lot of them are/were very beat-up. Later lenses are marked with a "II" on the filter ring and should be sharper.
    The Cine-Xenon 75 should cover a 35mm cine frame (18x24mm), so it's a good match to a 4/3 sensor.
    jwestra
    Ok thanks, so the 12-120mm is not really useful for any modern camera system.
    I can get the whole lot (the two 35mm and the 16mm) for 400 euro's. I gues this is really cheap right?
    Aug 2008
    Ontario, Canada
    96
    I couldn't say whether it's a good deal or not, but the Cine-Xenon was a high quality 6 element lens.
    Are you sure these are PL mount? I found a brochure online, and it looks like the Schneider lenses would initially have been sold with either an Arri standard or Arri bayonet mount:
    http://www.schneiderkreuznach.com/ar...tive_kompl.pdf
    PL mounts on either of these lenses may make them more valuable to videographers, especially those that use the Red One camera.
    jwestra
    You are right. The lenses are indeed arri mount but PL adapters are included in the deal.
