Results 1 to 7 of 7
Thread: GF-1 EVF --
    760
    GF-1 EVF --
    One issue that really frustrates me with the GF-1 viewfinder is that it is so easy to knock off the camera. I cannot tell you how many times I have almost lost mine. Now i am noticing the focus is off and even with the diopter adjustment I cannot get the image or recorded information into good focus.
    I suspect I can send it in for repair. I hope panasonic will provide a safety lock once the viewfinder is put into place.
    Chuck A
    Re: GF-1 EVF --
    The GF1 EVF is usable but still a disappointing piece of equipment. The resolution is low and it's a bit flimsy. I hope Panny brings out a replacement.
    Chuck
    Jan 2010
    West Chester, PA
    199
    Re: GF-1 EVF --
    My thought is that if you use the EVF a lot, a G1/G2/G10/GH1 might make more sense than the GF1. I think it is ok, but the G1 EVF is definite step up.
    Senior Member RichA's Avatar
    Jul 2009
    544
    Re: GF-1 EVF -- Is a poor viewfinder
    Quote Originally Posted by mark1958 View Post
    For me, this harkens back to my constant losing of eyecups and diopter correctors with the old Olympus SLRs.
    The current viewfinder is basically, a joke. Except for when you are in bright sunlight and the LCD is washed out, it serves no purpose, it is nearly useless because of its low resolution for focusing manual lenses, compared to the Olympus EVF or the G1's built-in EVF. A plain optical viewfinder would be as much use. I honestly wish they'd amend the GF1 to take a decent one, much as I wish Olympus would do away with their 4 years out of date 230k LCD resolution.
    Wesson
    Re: GF-1 EVF --
    Using mine yesterday for some test shots with M/F lenses mine nearly ended up not on the floor, but in the bin.
    I am bowled over with the GF1, but this EVF is so bad that I am going to forget the " Any lens" interchangeability, what made it worse was the Sun was shining and all I could see in the LCD was my face, and that's not to be recommended. So, 20mm, 14-45mm ( giving me ( 28mm,35mm,50mm,90mm and all station in-between). Five optical finders, and leave the camera set to idiot mode. Then all we want is Panasonic Olly to introduce a 10mm prime and that EVF could be put out to pasture............in the wheelie bin.
    Wesson
    760
    Re: GF-1 EVF --
    Has anyone used the Clearviewer www.clearviewer.com?
    I refuse to use manual focus lenses with the GF1 and i like the EVF primarily because i can use slower shutter speeds.
    Wesson
    Re: GF-1 EVF --
    No I haven't but it looks very clumsy. And yes at least with the EVF you don't have to adopt that supplication to the Gods posture.
