Results 1 to 23 of 23
Thread: Sun Sniper Strap
    Jan 2010
    315
    Sun Sniper Strap
    Has anyone experience of these?
    http://www.sun-sniper.de/index.php?i...per_strap0&L=1
    Two things appeal.
    First is that it is suggested that it can be worn, without the shoulder pad, under a jacket. For me it would be nice to go to a party, or gathering, with my camera less obvious for everyone to see. It would never be hidden - just less conspicuous.
    Second is that they make one with a steel insert and that must give added protection when walking around 'looking like a tourist'.
    Tony
    G1 owner in London UK
    May 2010
    29
    Re: Sun Sniper Strap
    It looks promising, but the website does not seem to have any way to order the product. I tried the "order now" and all I get is a screen saying that I have nothing in my cart.
    Wisconsin
    3,581
    118
    I tried to put it in the cart to see what the price is and there was an error message. It looks like they don't have all of the kinks out of the web site.
    It looks similar to the Y strap. I really like the Y strap concept, but have always been leery of putting my G1 on it ever since I heard about lug failures. This strap has the advantage of hooking onto the tripod mount. I'm just not sure if I would trust that or not, either. I'd be interested to hear a report from someone who has tried it.
    Senior Member mathomas's Avatar
    Dec 2009
    1,148
    This design seems to be multiplying. As Cindy mentioned, there is the Y-Strap. I believe Gordy's Straps has a similar thing (? - too lazy to look right now). Then there's the R-Strap (http://www.blackrapid.com/product/camera-strap/rs-4/).
    The idea is a good one, I think. Not sure which implementation is best.
    I use wrist straps, of course.
    Senior Member biglouis's Avatar
    May 2009
    2,124
    There is an interesting thread over at the Leica forum about the dangers of falling with a camera trapped between your back and the ground (in response to the best way of travelling with a camera when on a bike). The consensus is there is a danger to the spinal cord in this way. Not saying it is a serious issue if you are walking but one small drawback to the system. I also wonder if the tripod mount is designed to take the weight of the camera. Seems dodgy to me.
    Subscriber Member Streetshooter's Avatar
    Jul 2008
    1,431
    17
    I had the Y strap. It's a great idea but the camera kept turning around as it was hanging.
    As your walking, the camera kinda swings and pivots against your body....
    not again......I gave it away....
    Jan 2010
    315
    "but the camera kept turning around as it was hanging."
    So, do you think the Sun Sniper will work then?
    Tony
    Senior Member bradhusick's Avatar
    Seattle, WA USA
    2,498
    53
    Make your own for less. One climbing loop, one small carabiner, one split ring.
    Jan 2010
    315
    "Make your own for less. One climbing loop, one small carabiner, one split ring."
    Fantastic.
    Have you time to give us the URL's where we can find them?
    Tony
    Seattle, WA USA
    2,498
    53
    sling: (buy the long one) (rated to 5000 lbs load!!!)
    http://www.rei.com/product/755451
    carabiner: (rated to 4000 pounds!!!)
    http://www.rei.com/product/471041
    split ring - pretty common in key shops.
    Jan 2010
    315
    "but the website does not seem to have any way to order the product. "
    Click on 'Shop' in the left hand list of options and that seems to work.
    Tony
    Wisconsin
    3,581
    118
    Quote Originally Posted by bradhusick View Post
    Thank you for taking the time to point us in the right direction, Brad. Have you actually implemented this?
    Jan 2010
    315
    Sorry, Brad,
    I also should have said thank you. To your list I assume one would need to add something that locks into the tripod bush and provides a ring into which your split ring fits.
    Tony
    mco_970
    Tony,
    On the Sunsniper site, they have a link on the RHS of the page that shows how to make a DIY version... Pictures and everything. :-)
    Jan 2010
    315
    mco,
    Thanks. I have just had a look. How generous!
    Apart from the obvious a key difference is in hooking on to an existing strap lug rather than the tripod bush (which the proper version does). How the camera hangs will make quite a difference.
    As I said at the top I like the idea of having a G1 and pancake almost hidden under an open jacket. I do a lot of social photography at a nearby club and it would be nice if people were less aware that I had a camera to hand.
    Tony
    Wisconsin
    3,581
    118
    I have a small plate with an inlet for hooking on a strap. It screws into the tripod bush. I am not keen on just hanging from that, though. I'm going to see if I can figure out a way to secure the lug and the tripod bush (I'm anal). I really don't trust either alone.
    Seattle, WA USA
    2,498
    53
    I have made two of these and hang the Leica M8 / M9 from one strap lug. I have never had any problems. I don't hang from trees with this, I just use it like a neck strap except slung over one shoulder.
    Wisconsin
    3,581
    118
    Brad, I agree, I would not hesitate to hang my Leicas. I do hesitate with the G1. There has been a lot of concern about the flimsy lugs pulling out. The G1 itself is not a biggie, but I wouldn't want some of my lenses taking a fall.
    The parts that you pointed to for us look nice and sturdy and I'm anxious to give your strap a try.
  19. #19
    Seattle, WA USA
    2,498
    53
    Thanks, Cindy.
    The carabiner I pointed out is fairly big, so some might prefer a smaller 'biner.
  20. #20
    Jan 2010
    315
    Mine has arrived and I am convinced I will be happy with it.
    G1 fixed via the tripod bush.
    With a pancake it will be inconspicuous under a jacket.
    Tony
  21. #21
    Jul 2008
    1,431
    17
    Quote Originally Posted by Tonygamble View Post
    Tony
    Tony, look at the way the camera attaches to the strap. It's on a swivel release.
    It's gotta turn and swivel......
    If your walking, riding a bike etc...well...it's going to swing and bounce.....
  22. #22
    Jan 2010
    315
    Thanks Ss,
    I may end up giving mine away as well.
    But, at the moment I believe it fits my need.
    Tony
  23. #23
    Jul 2008
    1,431
    17
    Tony,
    I hope it works for you...I love the idea but can't make myself comfortable with it....
    good luck...
    Don
